Tractor Talk Discussion Forum
Hydrolic problem?
granger
08-28-2006 10:24:25
I have a 51 Farmall M with two-way live hydrolics & encountered a problem yesterday moing round bales with my loader. My hydrolics were working great, but as I started moving my 12th bale, I lost most of my lift. It would pick the bales up just enough to get off the ground, but NO HIGHER! My fluid level was fine, but I did notice a little oil leakage from my pump. Any ideas on what the problem would be on the lift with my bucket??? THANKS
buickanddeere
08-28-2006 15:37:58
 Re: Hydrolic problem? hydraulic in reply to granger, 08-28-2006 10:24:25
hydraulic
IH2444
08-28-2006 11:50:20
 Re: Hydrolic problem? in reply to granger, 08-28-2006 10:24:25
Ciykd be weak pump or cylinder seals. Bad hydraulic fluid ? sucking air into the system ?
As hydraulics are used the fluid heats up and thins out some, This can make marginal components show up.
