Tractor Talk Discussion Forum
oil burner 25 horse kaw
MARK RED OR GR
08-29-2006 15:17:37
have a 25 horse kawasaki ona 52'' JD MOWER LESS THAN 800 HRS ABOUT 3 YEARS OLD STARTED BUNING OIL RECENTLY DOES THIS MEAN BAD RINGS BAD VALVES OR SOME OUTHER PROBLEM IS THERE ANYTHING I CAN DO BESIDES REBUILD THANKS FOR ANY HELP GIVEN MARK
cannonball
08-30-2006 04:01:05
 Re: oil burner 25 horse kaw in reply to MARK RED OR GREEN, 08-29-2006 15:17:37
check your oil and see if you have gasoline in it.... my aunt has 2 lx's and i have 1 all are water cooled and the fuel pumps go bad put gas in the oil, if its thin enought it will smoke bad..i have wanted to go to electric and bypass these leakers... have nice day MAY GOD BLESS USA
Jmixigo
08-29-2006 15:57:37
have a 25 hp Kawisaki on my ztr mower
started smoking when you first crank it after sitting a week or so
got worse
dealer fixed it under warranty said there's a "recall" on the valve seals
MARK RED OR GREEN
08-29-2006 15:57:26
it smokes a little when normal use but when blades are engauged or put in a strain it pufs a little then returns to barly visable
Dave in Tx
08-29-2006 15:56:40
Mark, is that a water cooled KAW???
dr.sportster
08-29-2006 15:55:16
It could be many things.Even a worn lower end can allow more oil to be thrown up onto cylider walls and burned when rings are fine.I still read the service manuals for each motor I have before concluding one bad part because Ive been way off at times and disassembled things needlessly.Start with compression test.Frst dry then wet with squirt of oil.If it goes up it could be rings[valves ok]stays low valves and guides.Compression test has also been sorta replaced by leakdown testers which you can by in the car magazines and need a compressor to pump the air into the cyl.
landlord7012
08-29-2006 15:51:31
You'll need to check the compression, first dry then add 1/2 tsp motor oil thru plug hole. If compression is "low" dry then increases with addition of oil, it's more likely rings need replacement. Oil will not help busted rings, severely worn pistons or burnt valves. Could be valve guides/seals, does it puff real bad when you first start it? Could (slim chance) be a crankcase ventilation problem. Has it lost a lot of power? Not familiar with Kawasaki or the specs you need, just have general "small engine" knowledge.
Good luck,
ll
RAB
08-29-2006 15:42:02
Can be things that do not need a tear-down and rebuild. Determine what problem is first. Could be something simple like a blocked breather, or could be pin-pointed before dismantling - like compression test or compressed air test. Just try not to fly blind. Just likely to cost extra, that"s all.
Regards, RAB
BTW, turn off the caps lock and stop shouting. Easier on the ears!
