Tractor Talk Discussion Forum
Diesel Fuel Additive
Duane WI
08-30-2006 08:26:40
I have read a few post on this site about adding a lubricant if you are using road diesel in an old tractor. I have 504 Farmall that I use about 30 hours per year for brush hogging so I end up just buying fuel at the pump. I have seen people recommend ATF and 2 stroke oil. Are these the best choices? How much do you add? Does using a soy diesel blend help? I think most of the soy diesel I see is 2%. Thanks for the help.
BobHnwOh
08-30-2006 15:16:04
 Re: Diesel Fuel Additive in reply to Duane WI, 08-30-2006 08:26:40
A little Marvel Mystery Oil in fuel and crankcase,Bob.
JDknut
08-30-2006 09:22:49
I know a pup that uses two-stroke "skidoo" oil to help save the pump on his VP-44-pumped 2001 Cummins. I myself use Power Service and/or Marvel Mystery Oil which are rated my the manufacturer for use in Diesels. I like the Power Service the best.
sd pete
08-30-2006 08:41:17
I use Power Service. I also use the blended Diesel and I havent had any problems with it. And I always use no 1 in the winter to prevent geling.
Luke S
08-30-2006 09:21:37
 Re: Diesel Fuel Additive in reply to sd pete, 08-30-2006 08:41:17
Power service always seemed pretty good to me. I'd run a jug through one of my older trucks once and awhile and I told my wife it was like jet fuel. Sure seemed to perk the old truck up.
Luke S
08-30-2006 08:29:11
Put in a DIESEL FUEL ADDITIVE! ATF is called ATF because it goes in automatic transmissions. There are lots of good fuel additives out there, so why use some homebrew?
