Tractor Talk Discussion Forum
Thanks for the Replies
I Want a Tracto
08-31-2006 21:45:49
Thanks for all the replies. Really appreciate it. Very good advice so far.
Before I posted the original question, I had been checking out the classified ads on this website and several other websites as well (which I will continue to do), but I wonder if there are any other or some really exceptional sources that I simply haven't found yet.
I've tried five websites or more including the number one auction site, but few ads looked promising unless I had the time / money, etc to travel 500-miles or more.
As for the John Deere Model A, it was advertised as a "1931" model which (of course) is not correct as the first year for the Model A was 1933 or 1934. Didn't have the serial number list with me at the time but now I do and I may look it over again tomorrow.
Still figuring that some other slightly newer model would be more appropriate as my first tractor.
As I said, I appreciate the great advice so far and look forward to any other good thoughts on the subject.
I Want a Tractor
09-01-2006 09:40:02
 Re: Thanks for the Replies in reply to I Want a Tractor, 08-31-2006 21:45:49
Thank You all for the advice and information. Should help me in locating a good tractor.
J.J. in Idaho
09-01-2006 09:24:22
You might Check out. www.irontrader.com It is a montly magazine advertising older farm equipment in the Pacific Northwest.
Hugh MacKay
09-01-2006 05:28:43
I don't think I'd recommend the very early Fords or Fergies. These tractors are light and pull well with their 3 point implements, but draft control is very important. I'd tend to look for one built after the mid 50s. By that time the draft control was very much improved. Hydraulics and PTO had become live by then, ( no interuption of power to either when stopping or shifting gears)
You'll pay very little more for a MF 35 or a Ford 600, than for an 8N Ford or 2085 Fergie. I'd buy a Farmall H or a JD 50 with an aftermarket 3 point before I'd go with 8N or 2085. The H or the 50 will pull a two bottom plow without draft control. Bear in mind I am talking about tractors your going to work a bit. 8N's generally are way over priced as a work tractor. The 2085 not quite so bad on price.
wfw
09-01-2006 05:24:43
north carolina has a free paper "agriculture review" by the state, it is online also, perhaps your state has one also?? ads are for agriculture purposes, might try looking at a simular paper in state to you
frank
Jim.UT
08-31-2006 22:00:39
Another reason to look at the early Fords is they have a three point hitch. That means you can use most modern three point implements. The JD's and other makes from that time period generally do not have a three point hitch unless an aftermarket conversion has been added. That's why a lot of those other color tractors from the 30's and 40's are strictly doing parade and show duty while the 9N's 2N's and 8N's are still working.
Granted, most of them are just mowing or moving a little snow or dirt, but they got worked hard when they were new and it seems that at least half of them are still alive.
HAS
09-01-2006 01:55:35
 Re: Thanks for the Replies in reply to Jim.UT, 08-31-2006 22:00:39
Yes, you will want a 3-point hitch. I ave a Farmall A and the drag-behind implements are hard to come by. And if you want to go do some work somewhere else, they are hard to haul.
You newspaper is also a good place to find a deal. Check it early every morning and call at 7 AM and be ready to go look right away. There's competition in getting a real good deal on one, but if you are diligent, it will pay off.
