Tractor Talk Discussion Forum
OT Pintal Hitch Height
Uncle
09-02-2006 15:49:07
I am going to mount a Pintal hook an my old Mack as I am looking for a Tandem Dual Equipment trailer.
Does anyone knoe the ballpark height to mount the Pintal?
Brian
Gus
09-04-2006 06:21:42
 Re: OT Pintal Hitch Height in reply to Uncle, 09-02-2006 15:49:07
third party image
I have a GMC dump with a dual tandem econoline 12 ton trailer. The pintle is 26" off the ground. The trailer has an adjustable ring vertically. Most trailers do. I'll try and show a picture. If it doesn't work, e mail me through this site and I'll send it to you. Gus
Uncle
09-03-2006 09:44:49
I have not bought the trailer yet, I was going to mount the hitch to the truck while I am still searching for a trailer.
I have 1/4 plate for the rear of the truck that binds the flatbed with the chasis/frame. I see from Rod's reply that the hitch really needs to be between the frame rails.
I have a Mack Day Cab and the frame might be a little high for this.
Brian
RodInNS
09-03-2006 18:29:47
 Re: OT Pintal Hitch Height in reply to Uncle, 09-03-2006 09:44:49
Depends on your truck, but on mine the plate is about 36" wide and I think 24" deep. There is a good long section of plate below the frame. That is the reason for the gusset plates. They're welded vertically in front of the hitch plate, and up to the frame rail. Might not hurt you to stop by a local truck shop too. They can probably show you in a minute or two just what needs to be done, and there's probably a truck around the yard already set up. Whatever you do though, make it a good strong professional job. It's just not worth doing it worng and having hitch, plate and all torn out of the frame. We all know what can happen then. HTH.
Rod
RodInNS
09-03-2006 08:00:27
Not to sound like a smartass, but it will be whatever height it needs to be to level your particular trailer. I"ve seen them at a variety of different heights. The one on my eagle is set at about 20". It is probably low for some trailers; but then again, it"s too high for one little tri-axle I"ve got. I would go with Don"s suggestion, and find a few trucks around with a pintle on them, and measure them up. You"ve also got to watch the height to the box closely so that everything has enough room for going over rough terrain, etc. if there is overhang on the box (if this is a dump).
I would also hope that you fully fit at least 1" plate INTO the frame rails for the hitch, and then brace that forward with fillets of a foot or so in length (going forward). I"ve seen some pretty rickety hitches thrown onto rear cross members of tractors, and some more with light plates, unbraced, that were bent forward 6 inches or more from hard stops. When I fitted mine, I removed the rear cross member, cut the top and bottom of the frame rail to fit the plate in, then welded the entire frame surface on the front and back of the plate. Next, the tipping hinge was welded to the top of the plate, and fitted into the frame. Then the gussets were welded forward of the hitch plate. It isn"t moving. I lost a box once from hinges breaking loose. It"s not happening again. Good luck.
Rod
Don-Wi
09-02-2006 23:02:46
On most bigger trucks I see, I think it's right about thigh high so I'd say right around 30" or so. If you ever get around a dump truck that has one, break out the tape measure and do a quick check.
I'm not a professional, just observant of things I see.
Donovan from Wisconsin
