Tractor Talk Discussion Forum
WIs VH4D 30 hp engine ???
Jeff From WI
09-02-2006 19:29:55
Hi Guys, I"m looking for some help. I"m Looking at a Piece of equipment with a Wis VH4D air cooled Engine. How are these engines? Some guys I"ve talked too Say these Engines are Bad, Stuborn & Very Hard Starting!!! What"s Your Opinion on them??? Please Help. I Don"t Know if I should Buy this? Thanks Jeff From WI.
Jeff From WI.
09-03-2006 09:36:52
 Re: WIs VH4D 30 hp engine ??? in reply to Jeff From WI, 09-02-2006 19:29:55
Thanks Guys!!!!! !! It's Sounds like a Good engine then...
Bill(Wis)
09-03-2006 06:48:47
That engine is one of the best although I haven't been near one in 40 years. We had several on hay balers. Hard starting when hot was, in most cases, caused by fuel vaporization (vapor lock). They started good when cold. We used to just leave them run all day. Even when refueling. Just stand upwind. Chaff gets in between the baffle plates and the heads and can catch on fire quite easily. Always a big surprise when you're baling into the wind and turn around and see your engine on fire. We used ValvEase for the sticky valve problem. I would think fuel vaporization would be a bigger problem now as today's gasoline is more volatile.
`Bernie in MA
09-03-2006 06:26:09
I've been running a Hesston SP moco with that engine for 33 years. Only trouble was sticky valves. Make sure to put Marvel MO in it when you put it up for the winter. Electric start is good and keep an extinguisher handy. That fan will get electric short/chaff going in a hurry.
paul
09-03-2006 01:09:44
Very often they will not restart when hot.
Otherwise they are a good engine.
--->Paul
Roy Suomi
09-02-2006 21:02:04
I've used / rebuilt VH4D engines from skid loaders. They're just like anything else , worn out/hard starting..Fresh/stars good..They run all day long without problems..They're not bashfull drinking gas..They only run about 7 lbs. of oil pressure , but it's enough....I wouldn't be afraid of a Wisconsin..Tried and proven..
