Tractor Talk Discussion Forum
Flail Mower?
Chances R
09-03-2006 06:49:03
What is a flail mower. What do you cut with it? Thank you.
phillip d
09-03-2006 07:29:55
 Re: Flail Mower? in reply to Chances R, 09-03-2006 06:49:03
some flail mowers also were used for direct cutting hay and grasses.they have an augger behind the knives which feeds into a fan which blows the crop into a waggon for feeding cattle.can be bought for less than 1000 in like brand new condition around these parts.phill
MarkB_MI
09-03-2006 07:14:58
A "Flail mower" is a mower that uses a horizontal shaft with knifes attached to it, rather than vertical shaft like most mowers. (Not to be confused with a reel mower, which looks like an old-fashioned hand push mower.) There are a variety of flail mowers used for everything from finish mowing of lawns up to heavy brush. They are popular with state highway maintenance departments because they don't tend to throw debris out towards the road.
The main advantages of the flail mower are improved safety and finish over a conventional rotary mower. The flail knives pick up grass that the tractor tires have flattened, making for a better finish than a typical finish mower.
The main disadvantages of the flail mower are that they cost more to purchase and require more horsepower to operate than a conventional mower.
The most widely known manufacturer of flail mowers is Alamo, formerly Mott (link below). Several other implement manufacturers have produced flail mowers. I've been told that the Ford and John Deere flails were made by Bushhog, but I don't know that for fact.
If you're considering the purchase of a flail mower, check it out very carefully. I know from experience that many of the parts for older Mott mowers are outrageously expensive to replace. There are a couple of companies (Montage and Flailmaster) who make replacement parts for older flail mowers; these are quite a bit cheaper than the OEM parts.
