Tractor Talk Discussion Forum
E85 and what will burn it????
BLW
09-03-2006 09:28:22
we are going to get sc----d again, just watch-- the dealers won't even tell the truth on what cars, tks tractors are able to burn the ethenol w/o causing damage or at least negating the warr. they are going to spoil this like they do everything else-- the gov (haha) should step in right now and make sure the fair profit comes home to the farmer-- and the co's are forced to make a change over kit( should be fairly simple) to make motors ready to burn E85// the only way to make this feasable is to make the customers happy about it-- and have it fairly priced-- after all if they don't spend the money on ethenol, it will not work, and they won't unless its fair and easy-- can't blane them can you
Luke S
09-05-2006 06:27:25
 Re: E85 and what will burn it???? in reply to BLW, 09-03-2006 09:28:22
I don't understand? I just happen to be one of these dealers you are talking about. We have a big booklet on the front counter that anyone can walk in and get that clearly states which vehicles we curently sell that will run on it, the one's that we have sold in the past that will run it, and why a change over kit is not feasable as well as what will happen if you run it in a vehicle it is not designed for. These books were provided to us by our manufacturers, I think they are doing a great job of getting the word out an educating the public.
BLW
09-05-2006 06:33:48
 Re: E85 and what will burn it???? in reply to Luke S, 09-05-2006 06:27:25
are you a car dealer-- E85 dealer== or a gas station dealer== ane what area are you in--because up here in the northeast the dealers do not have the info and the car salesmen do not have any of the answerw or they won't give the answers-- we all know the trust worthyness of this business
Luke S
09-05-2006 09:32:42
 Re: E85 and what will burn it???? in reply to BLW, 09-05-2006 06:33:48
I apoligize for the lack of info. Yes I am a car dealer, and I am located in Missouri.
Fred Martin
09-04-2006 06:55:16
Well, whatever the future fuel is...I sure hope they don"t do a botch up job like they did when we converted to metrics. Fred OH
Leland
09-03-2006 21:56:33
After owning a FFV I would not recomend one to anybody they are a joke , and modifying one to use E85 would be very costly since you need a different ECM , LARGER INJECTORS , AIR FLOW CONTROL VALVE , STAINLESS STEEL FUEL LINES , SILACONE LINED RUBBER LINES , PLASTIC FUEL TANK , SPECIAL FUEL PUMP and lots of extra money to buy a lot of extra fuel that you will burn using E85 gas is still the best bang for the buck peroid .
Hal/WA
09-03-2006 21:24:35
If I lived in an area where E85 was available all the time at a reasonable price, I would consider building an engine for an older vehicle that would benefit from the ethanol's much higher octane rating. Maybe increasing the compression ratio to say, about 12 to 1 would increase the efficiency of the engine enough for it to be comparable to the conventional gasoline engine.
But of course I would have to use E85 all the time, since I am sure with that high compression ratio the engine would detonate badly, even with unleaded premium.
Some of the real high performance engines of the 60's had compression ratios over 10 to 1. I would bet that those engines, if they are still that high compression ratio, would work fine with E85 if the carbs were richened somewhat and the timing experimented with.
I think that EFI would also work, but the computer would need some reprogramming. If I was shopping for an aftermarket EFI, I would ask for assurances that the whole system was compatible with ethanol. Some of the aftermarket EFI systems are supposed to be fairly easy to reprogram, using a laptop computer. All it takes is time and MONEY!
I haven't read just how the current "flex-fuel" systems operate, but I suspect that they have some kind of sensor to identify the fuel being sent to the engine. Then the timing could be adjusted by the computer to a bunch more advance when alcohol is detected and maybe even change the cam timing. But I don't see how they could change the compression ratio in a flex-fuel engine, and that would mean that the efficiency would probably be quite a bit lower when using high alcohol fuel. But such an engine would still be able to run on conventional unleaded gasoline without pinging.
I also wonder if E85 would work well in the Winter. Very cold winter starts can be difficult with gasoline unless it is a winter blend, which must have more easily vaporzed components. Not so much of a problem with port fuel injection, but it can be a real bear with a carb.
I think that we will see more and more ethanol production in the future, due to the increases in petroleum prices. Petroleum has just been too cheap for too long to really consider alternatives, but now all that is changed. I am most interested in the possibility of economically producing ethanol from cellulose. Maybe all that straw and other crud out there will become worth something other than to become humus in the soil.
These are interesting times!
MarkB_MI
09-04-2006 05:14:11
 Re: E85 and what will burn it???? in reply to Hal/WA, 09-03-2006 21:24:35
Hal,
It's my understanding that flex fuel engines have sensors that detect oxygen in the fuel and adjust the mixture accordingly. Ignition timing is, of course, computer controlled and can be adjusted for the higher octane fuel.
E85 is only 85 percent ethanol in summer months. The ratio of ethanol to gasoline is adjusted seasonally to ensure good starting in winter months.
Ol Chief
09-03-2006 15:10:38
In the 1970 's I made numerous trips to Brazil.During those years I noticed zillions of V W automobiles operating on some form of localy produced bio fuel.Presumably alcohol.One could easily notice that it was not conventional fuel by the exhaust odors.I have no way of knowing what is going on down there but it my understanding that they are 100 percent independent of fossil fuel at this time.Maybe someone here has information on this subject.If Brazil has done it why can't we, Ifff there is a will to do as well or better?
RAB
09-03-2006 12:18:00
As I see it there are a few things going for this type of fuel:
1) It is more sustainable, or renewable, if you are burning a product like this.
2) Every litre that is burned is one litre less to import or whatever as crude oil.
3) Farmers will have an alternative outlet for their product.
4) Engines will become more efficient at extracting the energy as development progresses.
But there are some downsides too:
1) Too much fossil fuel is going into the production cycle.
2) Still too much fossil fuel included in the fuel.
3) Too few designs to burn 100% and not enough incentive to introduce both products together - engines and full ethanol fuel.
Perhaps there are some new developments for the very near future, but piece-meal change in hiking up the ethanol content is bad for everyone. We need an alternative fuel and an alternative engine for the future.
When a 100% engine is available, and could compete with the present engines, and the 100% fuel is available nationally, then the taxation incentives could really get to work on converting people to a green fuel.
Biodiesel is a better bet I think, but both together would be the real way to reduce global warming and conserve the remaining fossil fuels for generations to follow. After all, gas is almost a by-product in the cracker, so if less dino-diesel was produced the gas fraction could be used for other alternatives
lgc
09-03-2006 11:31:37
Consumer reports which i recieved yesterday had recent test results on E85 fuel. It didn't look too promising to me. Vehicles burning E85 got far les mpg than same vehicle burning gasoline. As much as 30-40% worse. Right now its not economically feasable to burn it. They also pointed out if gasoline increased price, alcohol would also follow suit. Again supply and demand.
MarkB_MI
09-03-2006 11:06:01
I'm afraid I didn't understand your post. The auto manufacturers are all, to my knowledge, very clear on which of their products are "E85 ready". And they are equally explicit that running E85 in any vehicle that isn't designed to use it is a bad idea.
As far as a change-over kit goes, the only reason automakers build E85 vehicles in the first place is because of government incentives. Otherwise, you would be paying a steep premium for an E85-ready vehicle instead of getting it for the same price as a non-E85-ready vehicle. How many people will shell out a thousand bucks or more for a conversion that allows them to burn E85?
As far as making sure that farmers get fair profits, you must be aware that grain is a commodity and obeys the laws of supply and demand. "Fair" doesn't really enter into the equation.
NcNE
09-03-2006 10:26:13
Dont get me wrong because I am all for farmers making money and reducing the dependency of foreign oil but I am really worried about the whole ethanol thing. Nebraska is one of the leading producers of ethanol. However, prior to the fuel hikes casued by hurricane katrina, the price of E85 was priced considerably lower than the regular unleaded and E10 and saw tons of support. Ever since then, E85 went from being anywhere from $0.75-$1.00 cheaper than regular to only within somewhere between $0.25-$0.30 cheaper. If only 15% of E85 is regular petroluem, how come it took so much of a hike?Now here is where it gets even better. The other day in Grand Island, Nebraska, the price of E85 was actually higher than regular unleaded. This is in an area that has at least 5 ethanol plants within 50 miles that are up and running. Here is what scares me. What is the future of the ethanol industry if E85 and similar ethanol based fuels end up costing more at the pump than the oil based fuels? I have studied the ethanol procution process and have found many of the rumors about it to be false. It seems to me that the people behind the pricing seem to be under the impression that if the petro companies can rake in that much money, why cant we.
JPatton
09-03-2006 20:03:11
 Re: E85 and what will burn it???? in reply to NcNE, 09-03-2006 10:26:13
The real reason that E85 is so high now is that it is now on the public board of trade. Now all the big speculators are in the game and since the stock market is their way of life.....well you get the picture.
john in la
09-03-2006 11:06:11
NcNE;
I do not want to sound like I am picking or poking at you but you brought up the question.
What makes you or anyone for that matter think that if I owned a ethanol company and it cost me 50¢ a gallon to make my product; that I am going to sell this product for 60¢ a gallon and make 1 million dollars profit a year when the market will bare $2.00 a gallon for my product and I can make 100 million profit.
Supply and demand rules and may even be our demise one day. This is the reason farmers will all ways be poor. It is to cut throat and to easy to get started in if a profit can be made. Where as big companies like oil need very large start up cost so not every Joe can get started in it. They can then charge what they want.
E85 was cheaper because the demand was lower because everyone could not use it. But once more and more demand is created for E85 the price will level out to the same as gas or a few cents less.
