Tractor Talk Discussion Forum
When to plant wheat
Devin Sparks
09-03-2006 16:50:41
I live in North Carolina. I am planning on planting all my fields with wheat this fall. When should I plan on planting. Should I fertilize when planting or later.
Thanks
Devin
Allan In NE
09-04-2006 07:35:22
 Re: When to plant wheat in reply to Devin Sparks, 09-03-2006 16:50:41
Hi Devin,
I'm rodin' the ground today and plantin' tomorrow (if that darned seed company has my order in). :>)
Allan
Devin Sparks
09-04-2006 15:59:33
 Re: When to plant wheat in reply to Allan In NE, 09-04-2006 07:35:22
Allan,
I am not sure I understand what rodin the ground is. Can you fill me in?
Thanks
Devin
Allan In NE
09-04-2006 16:45:46
 Re: When to plant wheat in reply to Devin Sparks, 09-04-2006 15:59:33
Devin,
Just got back from the field. Gonna hit "er with the drill in the morning.
A rod weeder is used as the last tillage pass before planting to insure there are no weeds in the field and to leave a smooth seedbed.
It has a one-inch rod that runs just under the surface of the soil. It spins backwards to travel direction and lifts the weeds up and out.
Guys like "em "cause they just "lift" the top couple of inches of soil and then drops it again. Really saves moisture.
Allan
third party image
third party image
John (C-IL)
09-03-2006 17:33:14
You need to check for the fly free (hessian fly)date in your area. Wheat requires a shallow application of phosphorus because of it's shallow root system. If you use MAP or Dap this will give you an adequate nitrogen rate until spring when you should apply addition nitrogen based on your stand and yield goals.
In our area of central Illinois (Champaign) the fly free date is October 1
