Tractor Talk Discussion Forum
How much does a small tractor weigh
ratch
09-03-2006 20:32:56
I am looking for a small tractor like a Ford 8N or 9N or maybe a Farmall Super C to play around with. I would like to use it on my property and sometimes trailor it to Mom"s house. I would like to know how much one of these weigh so that I can look for an appropriate trailor.
Any response will be greatly appreciated.
Ratch
Wm from NC
09-04-2006 06:40:33
 Re: How much does a small tractor weigh in reply to ratch, 09-03-2006 20:32:56
I have a 1940 9N which weighs approximately 2700 lbs.
jmixigo
09-03-2006 21:25:11
Look for a trailer with two 5,000 # axles and electric brakes to haul tractor, mower deck, etc. and have ample reserve capacity. 2 7,000 # axles with brakes on one axle would do, but you will never regret the bigger trailer.
old
09-03-2006 20:38:51
Most that are like that are around 2500-3500lbs. But it also depends on fluid in the tires, weights, equipment that may be mount etc.
Jim Broughton
09-03-2006 21:10:37
 Re: How much does a small tractor weigh in reply to old, 09-03-2006 20:38:51
A Ford 8N weighs right at 2400 pounds with only air in the tires. The Farmall "C" is a little lighter, but not much, about 2100 pounds on air, heck, even the little Farmall Cub weighs in at about 1500 pounds, so figure on the maximum weight and pulling power of your rig to haul it. Good luck! Jim B.
Hugh MacKay
09-04-2006 02:45:54
 Re: How much does a small tractor weigh in reply to Jim Broughton, 09-03-2006 21:10:37
Jim: Don't know about the Ford, but your light on the Farmalls. My Super A weighs 2350# with no weights added. Most C or SC are going to run about 500# more than the SA, thus the C or SC will be at least 2800# with no added weight. I was at a weigh in several years back and C, SC, 200 and 230 were all over 3000#. Now these guys did have some weight added.
