Tractor Talk Discussion Forum
O/T 79 blazer trans promblom - no park
perry in mi
09-05-2006 19:52:46
1979 blazer 350 turbo automatic trans. the parking gear doesent hold the truck anymore. when i put it in park, it will roll forward and make a clicking noise. it will hold the truck when i try and push it backwards. do you'all no if this trans has to come apart?, or can this be fixed by just dropping the pan. i have tryed to adjust the linkage but it did'nt help. thanks
Bob
09-05-2006 20:20:21
 Re: O/T 79 blazer trans promblom - no park in reply to perry in mi, 09-05-2006 19:52:46
The "parking pawl" and the mechanism that engages it can all be serviced by dropping the tranny pan.
On the other hand, if the toothed wheel the pawl engages is badly damaged, the tranny must come down and completely apart.
Sometimes, what you are experiencing can be caused by 2 bolts coming loose which hold part of the "apply" mechanism to the tranny case. Also, a spring can break.
Drop the pan, and have a (oily) look up at the park apply mechanism.
