Tractor Talk Discussion Forum
FORD JUBILEE
KEITH ROSEHART
09-06-2006 00:59:24
ON THE TRACTOR I AM NOW USING TWO THINGS ARE HAPPENING, I CAN NOT START THE TRACTOR NORMALLY BY THE STARTER BUTTON SO I HAVE TO JUMP IT TO START IT. SECONDLY ONCE IT IS STARTED IT USE TO RUN UNTIL I GOT DONE, MAYBE 4-5 HRS. BUT NOW IT SPUTTERS AND ALMOST STALLS OUT. NEED SOME HELP AND I AM NOT TO GOOD AT ELECTRICAL. MECHANICALLY I AM GOOD BUT NOT IN THE ELECTRICAL FIELD. THANKS
souNdguy
09-06-2006 07:48:56
 Re: FORD JUBILEE in reply to KEITH ROSEHART, 09-06-2006 00:59:24
Hmm.. sounds like you have a dead battery and a non working charging system to me.
If it won't start with e button and needs to be jumped.. that says dead battery.
Wont stay running? ( no battery power for points due to bad charge system ).
The fact that it used to run after being jumped seems to mean that the charging system used to work, even though the battery was bad..
so i'd look for a bad battery first.. then trouble shoot the charge system.
get your hygrometer, load tester and vom out..
Soundguy
dig
09-06-2006 08:58:42
 Re: FORD JUBILEE in reply to souNdguy, 09-06-2006 07:48:56
6 volt or 12 volt? What are you using to jump it? Like SouNdguy said it sounds like your battery needs replaced and the generater polarized.
About 3 years ago I had similar problems. The engine would take a long time to start and then it would run fine for awhile, spit and sputter for awhile. I figured it was fuel since the tractor sits most of the time. After I'd cleaned everything and replaced all the filters in the gas tank, gas line, and carb and it was still doing it, I started checking electrical. After a lot of cursing I found a wire had broke inside the insulation. The insulation wasn't broken or cracked, but vibration had broken the copper. The same vibration would make or break the connection. A new FNH wiring harness and voltage regulator and now it runs great.
Wiring a Jub isn't hard. Get a harness from Ford New Holland (or whatever they're calling themselves this month) and take it one wire at a time.
Remember: Clean, Bright, and Tight
