Tractor Talk Discussion Forum
Engine exhaust brakes on diesels
Mike Veen
09-06-2006 19:50:43
Who has tried exhaust brakes on their diesel pickup.What brand works the best.And will it screw-up the warranty on your truck?I have a 1995 7.3 power stroke.
Joe in Ne
09-07-2006 19:46:14
 Re: Engine exhaust brakes on diesels in reply to Mike Veen, 09-06-2006 19:50:43
Mike I have had an exhaust brake before and I have also had Jake brakes on trucks. I have a exhaust brake on our motorhome right now. You can't expect anything for results like a jake brake but they do work well. Mine came unhooked one time (After I had been complaining that it was nothing but dead weight) and as soon as I got home I told my mechanic to get it hooked back up. You have to set the relief valve so it won't hurt engine but not a big deal. One thing they also work well for is warming up your engine in morning. I think your dealer will even install one for you and that would for sure keep your Warranty. Just my two cents.
gold-leaf-deere
09-07-2006 19:30:39
I have a Jacobs Exhaust Brake on my 1997 Dodge Cummins, It is absolutely useless, have had to three different Cummins dealers and they can't make it work right. I ask for a refund and was denied a refund. About $900 wasted.
Mike Veen
09-07-2006 14:53:44
I think people are getting exhaust brakes and engine brakes (jakes) mixed up.Jakes can be a little on the noisy side at times but the exhaust brake doesn't sound like that at all. I think it actually muffles the noise abit because it blocking exhaust for back pressure not messing with valves and such.
willie j
09-07-2006 05:49:31
Mike
Gotta jump in here with my 2 cents worth. Former diesel pilot, now retired. Have no experience with small diesels, but...
Spent last 10 years driving 14 liter cummins with highest rated mufflers, Jake switch always on max.
Had a radio contact from CHP trooper going down Grapevine, grossing 80,000# holding at a controlled speed.
CHP- Hey big rig, your brake lites don't work!
Me- not using brakes, letting Jake hold it back! lites working now?(tapped pedal)
CHP- yup lites work now, but can't hear Jake!
Me- just good muffler!
By the way, company made me take a new tractor whenever mileage hit 450-500 thous miles. Only brake replacement was caused by leaking grease seal. DOT inspection at turn in time showed approx 50% service life remaining. Just my thoughts.
Willie
john in la
09-07-2006 11:34:02
 Re: Engine exhaust brakes on diesels in reply to willie j, 09-07-2006 05:49:31
Thanks for pointing that out Willie.
I also drive my truck with the Jake on max all the time and you can see it in our maintenance cost for brakes.
While the biggest hill we have around here is the overpass over a intersection a Jake still helps. Our system is set up that if you turn on the Jake and the cruise control (but not set for a speed) the Jake will not come on by just releasing the throttle. You need to touch the brake to set the Jake off. This system works well for us.
I will say the laws about loud Jake brakes has nothing to do with the Jake. The law needs to enforce the real problem and that is straight pipes with no mufflers.
willie j
09-07-2006 18:58:12
 Re: Engine exhaust brakes on diesels in reply to john in la, 09-07-2006 11:34:02
John
First of all, you're welcome.
Our rigs were set up that the Jake would not kick in below 900 rpm. Also would not kick in if clutch or accelerator were pressed about 1/4 inch.
About the "black box", ours were downloaded & printed out at every oil change/grease job. Just for giggles I asked the shop forman to let me see the printout. Surprising what is in there-max ground speed (mine 68), max rpm (1800), idling hours(don't remember), idling hours by percentage(20){this includes idling in traffic}, number of "hard stops"(3) percent of travel in top gear(93), number of brake applications per 1000 miles(250)[some guys showed 3000 applications per 1000 miles]. This from tapping brake to drop cruise control. Tap the clutch drops the cruise but doesn't show as brake application. Max & average oil press & radiator temp, etc. Whole bunch more stuff that I don't remembeer. Printout would be 2 pages.
Enough rambling for tonight.
Willie
GeorgeH
09-07-2006 05:13:34
I have what Jacobs calls an Ebrake (exhaust brake) in my motorhome (5.9 Cummins). The motorhome weighs a lot more than a pickup and I am very satisfied with the assist the Ebrake gives.
Hugh MacKay
09-07-2006 04:02:16
Mike: Engine brakes, either kind can be very useful. The biggest problem with them is too many jokers have used them for nothing more than to make noise, and that gives them a bad rap.
I have never used them in mountains, but I expect they can give huge savings both in wheel brakes themselves and in time it takes to let wheel brakes cool down.
I never drove trucks until I was 50, so I still don't know a whole lot about the internal workings of the engine or exhaust brake. I do know they can save your wheel brakes big time. I drove a 500 hp Peterbuilt (Cat) pulling 140,000 lb. gross load, 120 mile round trip. 10 miles of that each way was city driving on industrial throughfares. The city already had engine brake restrictions on all streets 30 mph and slower. Our route was 40 mph, thus you were allowed to use the engine brake, but many city residents were complaining.
I along with others were asked to try this 10 miles both with engine brakes and without. Most of us were hauling in excess of 100,000 lbs. This route was dotted with traffic lights, thus it was stop and go traffic. I found without engine brakes, I had to travel slower, allow more space in front of me, which city car drivers grabbed anyhow. At the end of the 10 mile cross city journey, wheel brake drums were so hot you couldn't lay your hand on them. With engine brakes you were able to drive much more with traffic and at the end of 10 miles the brake drums were not hot.
At a safety meeting after that we were asked our opinions. I told the group, small country villages hate the noise of engine brakes, and we should act on their wishes. Most small country villages don't have more than one or two traffic lights, thus heat build up on brake drums is not a factor. The city is much different, you will get the finger much quicker, holding up traffic than you will making a bit of noise. Keeping wheel brakes cool is much more important than a bit of noise.
thejdman01
09-07-2006 05:49:16
 Re: Engine exhaust brakes on diesels in reply to Hugh MacKay, 09-07-2006 04:02:16
Cities raising laws against jake brakes really gets under my skin. Recently the city I live in passed a no jake law on city streets. That really really really really erks me for many reasons. Most semis running through town to the shops and stores are making deliveries when the stores are open (during the daylight, yes i know some people work second shift). INdustrial parks in our town are on the outskirts of town. So nghtly deliveries most deliveries arent running through town. Most semis today are stock and these neew semis and mufflers are very very very quiet. Not at all like the old days. I asked the police chief if there banning jake brakes what about all these import cars w/tin can mufflers, and motorcycles w/straight pipes and these street motor cycles the wiiiii iinnnnn nggggg (rev up to about 13000 rpm as there doing wheelies through town. I said they are driving through town doing burn outs etc etc all hours of the day and night. He told me just becasue there is an ordinance dont worry babout it, it wont be enforced. I also said its kind of like sending your officers out without bullet proof vests and explained to him more and more people dont grow up on farms, they have no clue about safety and what these big trucks are, and people cut you off swerve infront of you etc i said anymore driving today we need all the help avoiding accidents we can get. (dont get me wrong m not a bad driver and know theres no substitute for proper following distances etc etc but how many of you out there know of the lady that comes from 3 lanes over (from your left) gets infront of your truck (cause your in the right lane slow lane trying to stay out of the way) and turns right. I have had people who literlaly dont stay in my lane for 3 seocnds the come into the lane and turn right then right there. They could slow down turn behind me cause they know there slowing down but they never do. Enough about my soap box. And to answer the above ?, banks makes about the best and has a kit so everythign works togehter. We have elctromagnetic brakes on our fire trucks uses electormagnetc on the driveshaft and that w/o using the brakes can lock the rear tiers up but when we went to put one of them on our grass truck (ford power stroke) they didnt make anythign for a truck that small.
Hugh MacKay
09-07-2006 07:00:53
 Re: Engine exhaust brakes on diesels in reply to thejdman01, 09-07-2006 05:49:16
jdman: I agree some of those little 4 cylinder cars are as bad as any Jake brake cowboy.
Nova Scotia, Canada has one of the most sensible Jake Brake laws anywhere. When this issue first reared it's head the province quickly jumped in and passed a law that states; cities, towns and villages can not have a Jake Brake law. The provincial law simply states it is illegal to use a Jake Brake where the speed limit is 50kph - (30 mph) or less. This sorted out the industrial corridors from residential streets quite well. The interesting part is not many towns and cities dropped their speed limits on those industrial corridors from 60kph down to 50kph.
RodInNS
09-07-2006 08:03:04
 Re: Engine exhaust brakes on diesels in reply to Hugh MacKay, 09-07-2006 07:00:53
Hugh,
Actually, those little signs are now popping up everywhere. Truro was one of the first areas where I first started seeing them, but I don't travel west of there very much. The signs are now quite prominent all around the Sydney area, or any other town limit. They're even popping up in rural areas near some of the quarries because people are squaking about the noise. For my own part, if somebody jumps out in front of me or cuts me off, the jake is coming on, sign or not.
Rod
Hugh MacKay
09-07-2006 08:38:24
 Re: Engine exhaust brakes on diesels in reply to RodInNS, 09-07-2006 08:03:04
Rod: I think if you check into this and happen get a ticket, that provincial law will have precedent.
Here is another kicker, and you can check this one with a lawyer. Your truck has onboard equipment to which a computer can be connected. In the case of an accident, your driving speed, what you had turned on or off at time of accident, can be picked from your truck after the accident. Let us assume a car pulled out in front of you, all be it illegally. Let us assume, had you gotten stopped 10' sooner you would not have killed the guy. I'm guessing you better wish, every item of factory braking capacity of your truck was turned on, even though the other guy pulled out in front of you.
One accident like this, especially if the dead guy is well connected, and every Jake Brake law in the land will be ruled unconstitutional. Truckers are sitting on a time bomb with this one.
RodInNS
09-07-2006 10:51:55
 Re: Engine exhaust brakes on diesels in reply to Hugh MacKay, 09-07-2006 08:38:24
Hugh,
I'm not sure exactly what the computer records in a heavy truck. The engine in mine is a N14-435 Celect.... and everything is electronically controlled, but I don't know what it's memory is. There was an incident here about 2-3 months ago where an indian woman got rolled out by a car carrier. The DOT and mounties were going up, over and down on that truck checking EVERYTHING. I know one of the mechanics that works in the shop where it was towed to for inspection. He told me the mounties were looking for the black box. He had a smart response they didn't like too much.... but long story short, they wern't finding that info that you suggest. However, that may have been an older mechanical truck. Dunno. This wasn't a speed accident anyway.... but I don't think they figured out just what happened yet.
Like you say though, I would use whatever braking ability the truck had, Jake included, in an emergency. Noise bylaw be dammed.
Rod
massey333
09-07-2006 06:28:27
J-Brakes are one of the best things,HOWEVER like old Pokey says you have the bad ones.We own Rental propertys close to a small town and get to listen to them at times,the reason towns pass Jake ords.is the ones that use them 100% of the time(You do not need them when ACCELERATING thru the gears like a lot of these Clowns are doing) two-three or more times between lights.As far as the small ones I don't notice them except the Hot Rodders with Dodge-Cummins are making a very bad Name for all Trucks.
ncdies48
09-07-2006 09:06:50
 Re: Engine exhaust brakes on diesels in reply to massey333, 09-07-2006 06:28:27
What is the hot rodder cummins comment about? I have a HOT ROD cummins and I am very responsible with it. And there are others including the powerstrokes and duramaxes that are being HOT RODDED as you say. Dont throw everyone in the same category yes there are idiots with these things but some of us use the extra horsepower responsibly.
massey333
09-07-2006 18:22:17
 Re: Engine exhaust brakes on diesels in reply to ncdies48, 09-07-2006 09:06:50
Didn't mean to offend anybody,but the Cummins-Dodge trucks I was speaking of are the ones that you can't be within 50 Ft. of them without being Smoked to Death and Made Deaf.(Can be heard aMile away and smoking worse than a Coal Train.)Plus they NEVER have over 300Lbs. in the Beds.I don't know of ANY Fords or Chevs. like them for Smoke or Noise.
ncdiesel48
09-08-2006 13:02:33
 Re: Engine exhaust brakes on diesels in reply to massey333, 09-07-2006 18:22:17
There are plenty of chevies and fords doing the same thing you came go to any local truck pulls that have diesel classes and see that. And yes if I hammer it my truck will do the same thing but I am responsible with it. Please dont put everyone in the same category though. And the reason you see more cummins like this because it is cheaper to get the power out of them.
RodInNS
09-07-2006 08:24:03
I would agree with you that some guys do use the Jake more than is necessary, upshifting etc.... but I find there are times when it is absolutely necessary to kill the engine with the Jake to catch a gear. I find that with a couple gears in low range when starting up a hill. That might depend more on what tranny you're using... but I know that with the 13 I have, I do jake upshifting on 2nd and 3rd in low range. Luckily, I'm out in the sticks, and nobody really cares too much anyway.
Rod
richard in nz
09-07-2006 02:40:50
Jake brakes make the bestest noise ever!!
Tim in OR
09-06-2006 21:27:53
There are "Engine brakes" and "Exhaust brakes". The "Engine brakes" Cut off the fuel, and open the exhaust valves as if they were compression brakes. that is what you see on Most big rigs (at least out here on the west coast). The "Exhaust brakes" restrict the exhaust to cause braking effect. Im my limited exposure to the Exhaust brakes, I saw many instances of the exhaust pressure blowing out the gaskets. Thus loosing the effect, and gaining that wonderful exhaust leak noise. As for use in pickups, I have no experience. I would however lean in the direction of the "Engine Brake" if it were available for my engine, and I could fit it into my budget.
This gained from my Big Rig experience, both in the shop (16 years) and my driving time ( 15 years)
Tim in OR
Tim in OR
09-06-2006 21:23:03
Tim in OR
Old Pokey
09-06-2006 21:18:39
 Wow thats close to my friends year. in reply to Mike Veen, 09-06-2006 19:50:43
I have a friend,....well, I have more than one, but just one that has an exhaust brake on his 97' 7.3. I've ridden with him when he used it. It does very minimal braking really, but it is fairly quiet in the cab. He has quite a few other hopup goodies on it though. Dont know if they effect the exhaust brake or not.
I'll write this topic down and make an effort to call him this weekend and get some brand and model info for you. If you dont hear back from me, remind me to do it. Dont be bashful about how you do it either. Sometimes I need a little extra pushing to get things done.:-)
J.J. Veenstra
09-06-2006 20:48:11
Just curious. Mike Veen. Is there more to your last name than Veen? Thank you. J.J. Veenstra
Mike Veen
09-07-2006 14:45:03
 Re: Engine exhaust brakes on diesels in reply to J.J. Veenstra, 09-06-2006 20:48:11
No,just Veen .Not to many Veen's around at all lots of different ones like vanderveen.But an old dike builder like yourself knows that all ready.I have some relatives in Arizona,used to do dairy.
NC Wayne
09-06-2006 20:42:14
Don't know about a pickup or the warranty but I can tell you that a proper exhaust brake works pretty good. Dad has a C6500 service truck (around 19,000lbs full time) with a 3116 CAT engine. We picked up job several years back that required us to spend a good bit of time in the mountains so he needed something extra for the trips back down. There's not a "Jake Brake" style engine brake available for the 3116 so he installed a PacBrake exhaust brake. He had been in the mountains with the truck on grades alot less steep than the one we had to travel so he knew what brakes alone would do. The grade down from Spruce Pine was several miles long with several tight turns and he never once had to stop for the brakes to cool with the exhaust brake activated. That said, a properly designed and adjusted exhaust brake won't damage the engine and although it doesn't have the braking ability of a true engine brake, it will definately make a huge difference when stopping on a grade or with a heavy load.
PAGlenn
09-06-2006 20:38:08
The big rig cowboys play with them all day long
on the road that fronts the farm. Do we really
need all the extra NOISE from the smaller diesels.
NC Wayne
09-06-2006 20:59:57
 Re: Engine exhaust brakes on diesels in reply to PAGlenn, 09-06-2006 20:38:08
Hey Glenn, I don't want to start a big deal here but what do you mean by "Play with them?". My service truck is a 20+ foot long Freightliner weighing in around 30,000lbs. It's got a Series 50 Detroit with a Jake Brake installed. I can't speak for ALL other truck drivers but you can bet when I activate the Jake I'm definately not "playing". It's nice to be able to let the truck slow itself down when you come up behind someone running slow in the fast lane, etc anything to keep from tapping the brakes and causing them to glaze. When they glaze the truck may not actually stop the next time you really need it. More commonly though it's used to keep me from killing some STUPID IDIOT that has the "big truck big brakes" mentality and pulls out in front of a 30,000 vehicle moving at 60 MPH, going 30 MPH, thinking it can stop on a dime. Better yet the ones that take the safe stopping distance I've left myself (because I know how much I need, they don't...see 'big brake mentality above') and cut it by a half to a third by pulling in front of me just as traffic comes to a complete stop....With the Jake I might stop on a penny but never a dime, the important thing is I don't stop on top of the idiot in question. Not only don't I want a death on my conscience I know as far as the media is concerned the accident is alway gonna be the trucks fault no matter what the actual circumstances might have been. Lastly and important but not as important as the above mentioned reasons is it's nice to be able to get a little extra life out of your brakes when it costs nearly $1200 a year to do all four corners..... .Just my .02 on the subject though..... .
Old Pokey
09-06-2006 21:12:49
 Re: Engine exhaust brakes on diesels in reply to NC Wayne, 09-06-2006 20:59:57
I have'nt driven for some time now. But I tell ya, I can sure tell how long a driver has been on the road by the way he uses his jake. A pro is so smoothe, you dont hardly notice he's using it. A beginner jakes down every gear from a governed wide open throttle. He/she'll do everyting in their power to get the truck up to speed just so they can jake down every gear.
But ya, a jake with a good muffler is definately an asset.
Ken Macfarlane
09-07-2006 09:33:19
 Re: Engine exhaust brakes on diesels in reply to Old Pokey, 09-06-2006 21:12:49
Gotta love some of the old dump trucks here with jakes and open stacks, talk about loud. I don't mind if they have a good muffler.
Actually the older I get the less I appreciate ridiculously loud mufflers. There are a few 4 wheelers here too that have no muffler and they rip up and down the road at night.
Mike Veen
09-07-2006 15:07:02
 Re: Engine exhaust brakes on diesels in reply to Ken Macfarlane, 09-07-2006 09:33:19
Exhaust brakes and jakes(engine brakes) are different. Jakes do valves and fuel,exhaust brakes just block off exhaust flow right by the turbo ,you know that hot rod thingy.They are suppose to work good when towing,hills and such.Pac brake is one BD,Banks I think.
B-maniac
09-07-2006 18:28:41
 Re: Engine exhaust brakes on diesels in reply to Mike Veen, 09-07-2006 15:07:02
I think we will all agree,there is a safety and longevity advantage with both type brake assist. The last I knew, quiet mufflers were still available and affordable. If you truckers want to stop all the hooplah,I suggest you put some on. Is there any "sane" reason you can't have your brake assist and be quiet at the same time? Heaven forbid it cost you 10 out of your 400-500 horsepower. There are huge semi's that pass me on the x-way,and I hear nothing but a powerfull "whine",and less yet when they brake. This post is not meant for them!!! The rest of you,GROW UP!!!
RodInNS
09-08-2006 07:47:48
 Re: Engine exhaust brakes on diesels in reply to B-maniac, 09-07-2006 18:28:41
I think when you see trucks roll past, and the ones that are quiet when braking... do not have a "jake" brake. There are several new style brakes out there. One is the "E-Brake" which is simply an exhaust brake, which doesn't make much noise. Jacobs also has another engine brake or retarder they call it, that doesn't make the noise of the old "Jake" brakes. However, the old style jake like my N14 has simply will not be silenced. That truck has 2 full length Stemco's behind the cab, and I hear it, and so does everybody else in the vicinity. The old Mack's were even louder. Sure there are guys that run straight pipes, and they're louder again... but there's no amount of muffler that is going to practically silence an old Jake. For what it's worth...
Rod
Mike Veen
09-07-2006 19:02:36
It seems I've opened a can of worms on this topic.All I was asking was if anyone has a exhaust brake on their diesel pickup and how they liked it,what brand it is.And maybe some of problems they might of incured.This is not a stab at truckers that keep the US of A rolling and Canader up there to. Thanks
