Tractor Talk Discussion Forum
Hay stacker I never saw before.
IaGary
09-07-2006 18:33:55
When returning from western Neb. today I saw several round stacks of hay that were about 20 feet across and about 10 feet high.
A little later I saw the machine that makes these stacks.
It looked fairly new.
It had a conveyor on the front that dumped in a tub.
How it dumped or compressed the stacks after you collected in the machine I do not know.
How do they move those without them falling apart?
Tell me about these machines.
Gary
Jerry/MT
09-08-2006 10:43:46
 Re: Hay stacker I never saw before. in reply to IaGary, 09-07-2006 18:33:55
Heck, here in Montana, they still use beaverslides to make hay stacks. I guess there are still some folks that know how to build them because I saw a new one in the Little Blackfoot Valley near Garrison a few weeks ago.
730virgil
09-07-2006 20:55:08
i had a friend that had a john deere stacker made a stack lot smaller than you are talking about . stacked hay and corn stalks with it corn stalks for bedding cattle sheds . fed hay up as soon as made . had them about fed up before snow came i think he had tarps for hay
IaGary
09-08-2006 05:23:20
 Re: Hay stacker I never saw before. in reply to 730virgil, 09-07-2006 20:55:08
Yep Virgil
We had those stackers around here also.
JD sold a few but most were Hesston.
As allen said they were replaced with round balers here in Eastern Iowa.
Gary
iowa_tire_guy
09-07-2006 18:59:11
Sounds like a Haybuster stacker. I saw several of them being used when we were out there in July. I had forgotten about them until then. The end of the conveyer is an arm that has a roller on it. The arm is controlled by a hydralic cylinder. The cage is rotating and as the hay builds up to the arm and roller they pack the hay down to make a tight stack. Works good in Western Nebraska where they can store hay outside, but would be a failure in Iowa because shedding the stacks would be expensive. And that is about all I know about them.
IaGary
09-07-2006 19:57:31
 Re: Hay stacker I never saw before. in reply to iowa_tire_guy, 09-07-2006 18:59:11
Iowa tire guy Where are you from?
Either I missed your post or you are new to this forum.
Gary
iowa_tire_guy
09-08-2006 07:34:56
 Re: Hay stacker I never saw before. in reply to IaGary, 09-07-2006 19:57:31
Gary,
I have been reading for a couple of years, but not saying much. I live east of Mt Pleasant. I am an 80's busted farming transplant from northern Kansas-southern Ne. Since I have never farmed here I understand more about wheat, milo and goofy hayhavesters. Had my brother-in-law from Kansas was here a few weeks ago and he just marveled at God's country. Black soil and green crops everywhere overwhelmed him.
ITG
Allan In NE
09-07-2006 19:23:35
Yep,
Had to have been down in the sandhills where the ranchers are still really big on loose hay.
Haybusters used to be all the rage until the round balers came out. This was about the same time that Hesston came out with those "bread loaf" stackers. Late 60s or early 70s.
The guy running the Haybuster really had to be on his toes tho, because if he didn"t get the stack compressed enough in the center and didn"t build the "roof" of the stack right, the center portion of the stack would "dimple in" with time and leave a depresion in the center of the stack.
Snow and rainwater would then collect in the center and you eastern guys know how moisture can rot hay.
Another one of those things. They used to be everywhere around here and now I can"t even find a darned picture of one. :>(
Allan
WyoDave
09-07-2006 19:29:28
 Re: Hay stacker I never saw before. in reply to Allan In NE, 09-07-2006 19:23:35
You know Allan, I've never even seen one of those. There were a couple of those loafers around, but I'm guessing you could buy one of them rigs for a little of nothing anymore. Some ideas just get replaced I guess.
David
Allan In NE
09-07-2006 19:40:42
 Re: Hay stacker I never saw before. in reply to WyoDave, 09-07-2006 19:29:28
Yep,
Trouble with the those types of machines, not only do you have to have the stacker, but you need a way to move the stacks too. Hesston had a different mover for every sized stacker they sold.
A friend of mine had one of the big 60A loafers for sale. Think he was asking $400 maybe?
Anyway, no takers I guess, 'cause the last time I saw it, they had it tore down in his yard and was making a trailer out of it.
The darned round balers just knocked everybody in the hay-machinery business in the head. :>)
Allan
RJ-AZ
09-07-2006 20:41:02
 Re: Hay stacker I never saw before. in reply to Allan In NE, 09-07-2006 19:40:42
Those Haybuster stackers were real big back in the Dakotas bin the 70's. I saw a mover and feeder that had a graple arm with backhoe type cotrols for feeding them.
My brother has a Hesston 30, 30A, two movers and a feeder attatchment laying around now that he went to round bales. I got the Cherry on that Hesston 30 stacker in 1972. You wouldn't believe the lashup feeding rig of a 3000 Ford with a Farmhand PTO hyd pump, F11 hyd reservoir, Gresen twin spool valve on the toungue of the Hesston mover and two really nice pitchforks to feed the hay off with. That was before we got the feeder and hooked it all up to a 1086. Had an old Combine gravity grain tank to feed barley cake mounted on the toungue of that rig.
iowa_tire_guy
09-07-2006 19:58:48
Back in the early 80's when I was trucking in Nebraska the guys around Burwell and Ord were still pretty big on putting alfalfa in stacks with their hay bucks on loaders. I hadn't seen that since the 60's but I didn't see hardly any round bales there, just loose stacks with the 3 cuttings in the same stack.
IaGary
09-07-2006 19:46:42
Allen did they move those round stacks?
Or just feed them where they set?
Gary
