Tractor Talk Discussion Forum
O/T Wiring question
37 chief
09-09-2006 16:56:59
I am still in the process of hooking up my compressor. When hooking up the ground wire in the pannel, it looks like it is connected in the same location as the nuteral wire, or Should I hook it directly to the metal panel box? Stan
Bus Driver
09-09-2006 18:11:38
 Re: O/T Wiring question in reply to 37 chief, 09-09-2006 16:56:59
In the first panel on a premises, the ground and neutral can be "tied together". After the first (main) panel, the neutral and ground must be separate. The neutral is not grounded after the first panel and in fact, must be insulated from the ground except within the main panel.
