Tractor Talk Discussion Forum
FIRING ORDER
Earl Kinchen
09-11-2006 15:29:01
WHAT IS THE FIRING ORDER FOR A 1950 SUPER AV GARDEN TRACTOR
Joe (Wa)
09-11-2006 17:40:31
 Re: FIRING ORDER in reply to Earl Kinchen, 09-11-2006 15:29:01
Go to a hardware store and buy 4 plugs that will fit the spark plug holes. Crank the engine in the direction of rotation and the plugs will pop out on the compression stroke of each cylinder.
1-3-4-2 and 1-2-4-3 are both very common in 4 cyl engines.
Joe
Yugrotcart
09-11-2006 17:40:11
1-3-4-2
#1 being at the radiator end of the block.
tinyy
09-11-2006 17:11:12
I-T manuale says 1-3-4-2
Nebraska Kirk
09-11-2006 17:10:48
Fireing order for the IH 4-cylinder engines is 1-3-4-2
jake4
09-11-2006 16:48:53
4 cyl engines usually 1-2-4-3, Ford and Oliver are examples.
Stan - Florida
09-11-2006 16:16:08
If I remember right from 4-H tractor maintenance days some 50+ years ago, it should be 1 4 3 2 or 1 3 4 2. Sure hope my memory hasn"t turned to mush.
Stan
jeffcat
09-11-2006 17:13:23
 Re: FIRING ORDER in reply to Stan - Florida, 09-11-2006 16:16:08
I have seen both Stan and if you want a real wild wheesel try tha V8 in a Travel All. The corn binder starts on #8 plug wire not #1. Jeffcat
