Tractor Talk Discussion Forum
Case DB 885 lift problems
gdoss
09-11-2006 18:59:34
I inherited this good ol tractor, but no manual. The lift is stuck in the up position. It still responds to forced high lift, but will not go down. Is there a lock on this thing or does it just need a good service Job?
richard in nz
09-12-2006 00:15:22
 Re: Case DB 885 lift problems in reply to gdoss, 09-11-2006 18:59:34
Yes there is a lift latch on the left side on the rockshaft bracket. A curved lever about 21/2" long. Pull control lever to 'select' (the red sector against the spring) and pull up the lever to disengage. Pushing the lever down at any time will cause the linkage to lock the next time it is raised. The lift latches have been known to sieze in and ours used to latch on its own when the tractor was new but was sorted under warranty.
