Tractor Talk Discussion Forum
Flat Proof Fill tires
Tom Wise
09-12-2006 07:26:45
I have been running my little Ford with the Green Slime in the tires. I needed some more weight up front and Fill the tires with water.
Well that pretty Much renders the Slime useless.
I had a Flat in less than an hour. What can I put in there that won"t leak out , and is heavy Thanks
Tom
glennster
09-12-2006 09:13:39
 Re: Flat Proof Fill tires in reply to Tom Wise, 09-12-2006 07:26:45
it ran around 900.00 for all 4 tires. it seemed pricey at the git-go, but we had many flats with the machine and was a pain in the butt. we put a set of 4 new tires on the machine and then had em urethaned. haveent had a problem with the tires at all and since adding the weight havent tipped the machine over either.
BLW
09-12-2006 07:46:36
how much did the urethane cost-- we seem to have dealers here that think it is gold
glennster
09-12-2006 07:41:35
we had our skid loader tires filled with urethane from the local fs dealer. it adds about 400 lbs to each tire. you need to put tubes in the tires. the urethane sets up and the only way to get the tire off is with a sawzall. the tires will never go flat.
