Tractor Talk Discussion Forum
Shop changes
Jerry Cent. Mi.
09-12-2006 15:51:06
I finally decided to insulate and sheet the inside of my shop. I am thinking of using 5/8 flame check but my son thinks that white sheet metal would be better. I only heat it when I am in it so I was wondering what you fellows have experenced and which material would heat the best.
J Schwiebert
09-12-2006 19:31:24
 Re: Shop changes in reply to Jerry Cent. Mi., 09-12-2006 15:51:06
Around here most people go to the sheet metal and we have it also. 18 inchs of blown in insulation in the ceiling. Very easy to heat, Walls are also insulated and have sheet metal on them Helps with visiability on cloudy days too.
Gus
09-12-2006 16:55:28
When I built mine I drywalled the inside over 2x4's run horizontally. Then blew the whole cavity with cellulose. Works great. No drafts, heats easy. Put white steel on the ceiling and blew 12" of cellulose on top of it. Gus
Matt Smith
09-12-2006 16:32:04
General contractor here. I've done both in the past year and the drywall was the cheaper solution.
Midwest redneck
09-12-2006 15:56:06
I would check with the building code, I am pretty sure that 5/8 drywall is code for a firewall. Not sure about sheet metal. Where in Cent. Mich. are you at? I am about 15 miles from Flint.
Jerry Cent. Mi.
09-12-2006 16:56:37
 Re: Shop changes in reply to Midwest redneck, 09-12-2006 15:56:06
20 miles south of Grand Rapids, Little town called Middville.
