Tractor Talk Discussion Forum
Fuel Problems
Dug
09-13-2006 11:15:32
I have a JD F935 diesel mower. Air is getting into the fuel system. It mows fine for a while, then starts to sputter and idles down. I can bleed the system and it goes back to running fine for a while, then it starts sputtering again. Why or how is air getting into the fuel system?
bradk
09-13-2006 15:56:26
 Re: Fuel Problems in reply to Dug, 09-13-2006 11:15:32
Not sure of the fuel system,but if it has a strap on style filter,the rubber seals might be getting hard,thus not sealing and pulling in air.
Had this problem on our Oliver 1800c diesel.New filter,no more problem.~brad
Allan In NE
09-13-2006 15:32:35
Dug,
That sounds like a plugged fuel or air filter.
When a diesel gets air in it's system, they typically speed up, not slow down.
Allan
Eric in IL
09-13-2006 12:35:39
I have not been arround JD mowers so I don"t know if this relates to your problem or not.
I have a "91 Kubota diesel. When the fuel filters are becoming plugged it will fall on its" face for 30 secs or so, then run fine for about 20 minutes. Then it repeats.
I imagine you have already replaced the filters, but if not I would do so. Sure beats looking for a leak if the filter/filters are the problem.
MSM
09-13-2006 11:51:21
Check the fuel lines and clamps from the tank to the filter,and from the filter to the injection pump.You are sucking air from a cracked line or loose clamp,or the switching valve if it has 2 tanks. As old as the machine is it might pay just to replace all the rubber lines,clamps and fuel filter as preventative maintenance.
JT
09-13-2006 11:33:48
due to the age of an F935, I would start loking for cracked injector lines or where the connector hook to the injectors them selves. Unless you have a pump wiht a crack or bad gasket, injector lines are the only place I would think you could get air.
