Tractor Talk Discussion Forum
Rusty Muffler.
mike in Ind.
09-13-2006 12:32:20
I have I cub cadet 71 that I want to replace the muffler on but I can't get the old one off. There is a 90deg. elbow the come out of the engine andhas threads on the end that the muffler itself spins on and it's rusted fast there. I have sprayed it with PB blaster several times and heated it with a propane torch afew time also and nothing seems to help. Anything else I should try? I am considering cutting it of with a hack saw. Any ideas? Mike.
coflyboy
09-13-2006 16:12:44
 Re: Rusty Muffler. in reply to mike in Ind., 09-13-2006 12:32:20
There are many who will disagree with me but I use as oxy/aceteline torch. Heat it until it just STARTS to turn red. Back that muffler out. If it still wont come out heat it til it gets just a little redder.
Has worked every time for me.
Don L C
09-13-2006 18:13:57
 Re: Rusty Muffler. in reply to coflyboy, 09-13-2006 16:12:44
The only way..... .
The best way..... .
glennster
09-13-2006 13:47:47
you may try and grind a slot on the inside with either a dremel tool or a hacksaw blade and then use a chisel to fold the pipe to the inside so it can be removed. dont go too deep and hit the threads in the block
