Tractor Talk Discussion Forum
plow mouldboard rust protection
550Doug
09-16-2006 15:04:27
I've been using blobs of grease smeared over the mouldboards but its messy, so I'm looking for a spray-on solution. What do you guys use?
Thanks
RodInNS
09-17-2006 08:02:25
 Re: plow mouldboard rust protection in reply to 550Doug, 09-16-2006 15:04:27
The cheapest rattle can enamel Wally has to offer. One can does 4 bottoms. Cheaper than grease, and cleans off easy in a few passes. Like the others have said, just smear it on and forget it.
Rod
souNdguy
09-16-2006 21:55:13
My vote is for left over spray paint.. or a food grade grease.
No need to be extra - cruel to the environment by using regular axle grease... besides... the paint stays on longer...
Soundguy
James2
09-16-2006 21:39:48
The local farm store sells a product called "plow coat" which comes in a gallon can. I think it costs $5-6. Graphite products are more costly. I use a cheap brush and coat plow bottoms, ripper points and cultivator shovels. This stuff will endure outside storage. The stuff I really liked to use in the bygone days was old wagon wheel hub grease. It was rubbery and would also stay-on forever.
bradk
09-16-2006 19:15:38
Every so often I go to the local land-fill and get a box of spray paint.About every color you can think of.Handy for jobs like this(and other misc.) and they're happy to get rid of it for the taking. ~brad
Bob M
09-16-2006 18:50:43
Same as Vally Farm - oldest left over rattle can paint left laying around. Otherwise the canned paint left over from the last time I painted the bathroom ceiling, etc; brushed crudely onto the moldboards and coulters.
Key principle is to never BUY paint for a job like this - anything left over works fine!
Bill(Wis)
09-16-2006 18:47:10
I used heavy grease one year. I still had to go down by the river where there's a sandy spot to clean off the moldboards before plowing. Coarse sand does it real quick. Finally solved the problem altogether. Have not moldboarded anything since 1961. Still have the plow though, "just in case".
Bill(Wis)
09-16-2006 18:50:37
 Re: plow mouldboard rust protection in reply to Bill(Wis), 09-16-2006 18:47:10
PS to above post: I could hook that plow to my WD Allis today, go down to that sandy spot by the river, and have those moldboards shining like mirrors within about 20 minutes. After 45 years of sitting outside.
vally farm
09-16-2006 18:36:42
What ever rattle can of paint I have laying around. Cheaper the better. They all will stick well to a clean surface and protect the plow all winter too. Mike
john *.?-!.* cub owner
09-16-2006 18:21:26
Cahinswa bar oil, slpaped on with a brush.
Mike M
09-16-2006 17:47:53
John Deere used to sell a soft black plow coating made just for them. They may still sell it .
BigMarv1085
09-16-2006 17:38:25
LPS rust inhibitor or Corban 35, they contain BMS3-35. They are used in commercial A/C to prevent corrosion and are moisture inhibitors.
Hugh MacKay
09-16-2006 17:13:22
Doug: Graphite, I've been using it on plow wear parts since I bought my cyclo corn planter in 1975. In the beginning I painted on with a brush, today I use spray cans. The beauty of graphite, yes it wears off but in the process the dry lubrication scours as well or better than any shined up moldboard.
Nebraska Cowman
09-16-2006 16:54:18
Grease is by far still the best. I wouldn't waste my money on that spay-on junk.
third party image
Gold for the mistress,
Silver for the maid.
Copper for the craftsman,
Cunning in his trade.
"Good" said the Baron sitting in his hall,
"But iron- cold iron - is the master of them all."
-Rudyard Kipling
the tractor vet
09-16-2006 15:58:01
The cheapest can of spray paint that ya can by and don't be to fussy on how ya get it on there as your just going to ware it off come next spring.
Gerald J.
09-16-2006 15:38:57
Tractor and farm stores often carry a soft spray paint made for the purpose. I find it won't stand sun and snow for more than a year or two outside but its far better protection than grease. Otherwise any low priced spray paint will scour off once you go to plowing again.
Gerald J.
Leland
09-16-2006 15:07:44
good primer spray it on i like the stuff with rust inhibator
