Tractor Talk Discussion Forum
f-12 power-trol
Doug75
09-17-2006 15:39:20
How does a power-trol on a f-12 farmall work and where is it located?Thanks
Fawteen
09-18-2006 01:46:02
 Re: f-12 power-trol in reply to Doug75, 09-17-2006 15:39:20
I have one on my '38 F14. As Cowman said, gear pump off left side, cast "manifold" to lift unit under seat. Lift unit is reservoir for system, control lever is on front left side of unit.
As is typical for the time, it's an "all or nothing" unit. Flip the lever one way and the rockshaft arms are all the way forward (or down) and flip it the other way, and they're all the way back (or up).
Entire unit is dead simple, common lip seals on the shafts, easy to make your own gaskets where needed.
If you have more questions, I'll watch this thread.
Doug75
09-18-2006 08:58:15
 Re: f-12 power-trol in reply to Fawteen, 09-18-2006 01:46:02
Thanks for the help.I thought that's what it was.My dad had it on his 12 it would lift all the cultivators.Thanks again!
JOHN HARMON
09-17-2006 16:23:33
Never knew they were equipped with such an attachment.Dad had one but every attachment he had, Cult.,Mower etc was hand lift.Any way "Power-trol" is J.D. terminology isn't it?
Nebraska Cowman
09-17-2006 17:14:51
 Re: f-12 power-trol in reply to JOHN HARMON, 09-17-2006 16:23:33
Oh yeah. IH made an optional hydraulic power lift that consisted of a pump driven off the belt pulley shaft and an under-seat mounted rockshaft. Not very common but I have seen pictures and a few at shows.
Nebraska Cowman
09-17-2006 17:39:49
 Re: f-12 power-trol in reply to Nebraska Cowman, 09-17-2006 17:14:51
No, I'm wrong. The hydraulic pump drives off the left side. Maybe somebody will straighten us out.
third party image
Fawteen
09-18-2006 15:20:32
 Re: f-12 power-trol in reply to Nebraska Cowman, 09-17-2006 17:39:49
Well, you were actually right, too, in a way. It drives off the same shaft as the belt pulley, just the other end of it. In fact, to install the pump, you remove the bearing and bearing holder from the outside of the transmission case, and bolt the pump (with appropriate shims) in it's place.
