Tractor Talk Discussion Forum
How much do the tow of them weigh??
old
09-20-2006 19:43:36
I'm thinking about hauling 2 tractors to a show this weekend but not sure I can haul them both at once. One is a 1935 JD-B on steel wheels and the other is an Allis C. Neither one has weights or fluid in the tires. So will they be less then or around 5500-6000 LBS togeather??
Thanks
Leroy
09-21-2006 07:19:57
 Re: How much do the tow of them weigh?? in reply to old, 09-20-2006 19:43:36
Nebraska Test no. 0232 1935 John Deere B Max belt HP 16.01 and 3275# but does not say if steel or rubber. Dykes auto and gas engine for 1937 says 2704# with 7:50X36" rear and 5:00X15" front special equipment so I would guess weight is on steel.
Luke S
09-21-2006 06:20:51
Big question is, what are you hauling with?
old
09-21-2006 07:53:36
 Re: How much do the tow of them weigh?? in reply to Luke S, 09-21-2006 06:20:51
I will be hauling it with the same set up I use to haul my Super 88 Oliver which comes in at just under 5500LBS.
Hugh MacKay
09-21-2006 02:15:18
old: Are you sure the JD-B doesn't have fluid. haha. Could resist as you said neither.
old
09-21-2006 07:52:07
 Re: How much do the tow of them weigh?? in reply to Hugh MacKay, 09-21-2006 02:15:18
Yep the B has fluid in the tires. It what ever is there asfter a good rain LOL
GeorgeH
09-21-2006 04:48:45
AH, that's good..... ..... ..
CLW
09-20-2006 21:46:07
I agree with 3275 lbs. on the unstyled B.
old
09-20-2006 21:50:15
 Re: How much do the tow of them weigh?? in reply to CLW, 09-20-2006 21:46:07
Well then figureing with the numbers I'm seeing thats around or under the 6000LBS I like to saty under so maybe I can haul 2 tractors to the show.
Thanks
sammy the RED
09-20-2006 20:15:20
My book seez:
AC C weighs 2300 lbs.
JD B weighs 4126 lbs.
souNdguy
09-21-2006 05:37:46
 Re: How much do the tow of them weigh?? in reply to sammy the RED, 09-20-2006 20:15:20
The 4126 B is the styled one with the cast heavy rear centers.. not the lighter stamped steel centers. or spokes of the early units.
Soundguy
old
09-20-2006 20:59:09
But is that an early JD-B unstlyed or a later styled B. I know that can make a big differance
paul
09-20-2006 20:05:53
My book lists the JD B at 3275#.
The AC C at 2200#.
These are typically the dry weight, as light as can be from the factory.
--->Paul
