Tractor Talk Discussion Forum
HYDRAULICS
KATHY DARNELL
09-21-2006 11:41:22
MY HYDRAULICS ON MY 1957 FARMALL QUIT WORKING. HOW CAN I FIND THE PROBLEM? AND WHERE DO I START?
AL BANE
09-21-2006 21:17:32
 Re: HYDRAULICS in reply to KATHY DARNELL, 09-21-2006 11:41:22
DRAIN ALL HYDRAULIC FLUID. CLEAN HYDRAULIC FILTER AND REPLACE AND THEN FILL WITH NEW HYDRAULIC FLUID. ONCE FILLED , WORK THE HYDRAULIC LEVERS 10-12 TIMES UP AND DOWN TO GET AIR OUT OF THE LINES.{ YOUR FLUID MAY BE LOW, NOW.}
KATHY DARNELL
09-22-2006 06:50:29
 Re: HYDRAULICS in reply to AL BANE, 09-21-2006 21:17:32
THANK YOU I WILL TRY THAT
al bane
09-22-2006 09:50:13
 Re: HYDRAULICS in reply to KATHY DARNELL, 09-22-2006 06:50:29
Where you put the hydraulic fluid in, be sure to leave that plug out until you work the levers back and forth 10 -12 times. This gets the air out of the lines and also may get the excass fluid out.Too much fluid could damage the system.
Allan In NE
09-21-2006 12:02:20
It would help these guys a little if you could tell us what model of Farmall and which hydraulics don't work.
I.E. What exactly is the problem? Steering, remote cylinder, etc. ??
Allan
KATHY DARNELL
09-21-2006 20:48:32
 Re: HYDRAULICS in reply to Allan In NE, 09-21-2006 12:02:20
1957 FARMALL IH 450LP THE REAR BLADE AND POWER STEERING WON"T WORK.
