Tractor Talk Discussion Forum
hey Allen, another International question
Jonfarmer
09-21-2006 17:17:32
talked with the folks at the local Case IH dealership, they want to test the pump on it, so I am going to take it out to them in the morning and they can test it off the remote. Now, they confirmed that it did indeed have a seperate pump for the pto, and the other pump runs the power steering, the 3pt, and the remotes. Which pump was it that you replaced?.
Allan In NE
09-21-2006 17:34:39
 Re: hey Allen, another International question in reply to Jonfarmer, 09-21-2006 17:17:32
Jon,
My tractor is a 966, so it has 3 pumps. The one I replaced was the "hitch pump" or "main pump", which also handles the remotes.
A separate pump handles the PTO and yet another for the steering, brakes and the T/A.
Now, I would "guess" that on your tractor, one pump "probably" handles the remotes, hitch and the steering. Just can't say for sure tho.
You're on the right track; take it to the big boys if you don't have an IT manual. They can test it and you can still fix it yourself if ya like.
Allan
Jonfarmer
09-21-2006 18:04:30
 Re: hey Allen, another International question in reply to Allan In NE, 09-21-2006 17:34:39
Oh, I thought yours had just two pumps. They told me that 1 pump ran the steering, hitch, and remotes and I am guessing problably the brakes as well. My tractor doesn't have a t/a and I asked if the pto was run off a seperate pump, and they said yes, so that would explain why the pto doesn't fail when everything else did.
Ted in NE
09-21-2006 18:55:31
 Re: hey Allen, another International question in reply to Jonfarmer, 09-21-2006 18:04:30
The 484 has one hyd pump, flowdivider in the MCV that pump is behind gives priority to the steering. Rest of oil is directed to remotes, pto, lube & brake circuits. If pto valve is not properly adjusted or linkage is rusted so pto valve is not in proper position remotes & 3pt hyds will be afected. Your dealer is probably aware of this. Just something to look out for.
Ted
