Tractor Talk Discussion Forum
OT - IH 6.9L Diesel V8 (Early 80's)
mrn
09-23-2006 17:33:07
Does a broken timing chain mean bent valves?
David A. Hodson
09-23-2006 18:01:19
 Re: OT - IH 6.9L Diesel V8 (Early 80's) in reply to mrn, 09-23-2006 17:33:07
Yes it is you've got the gear on the crank then the cam and lastly the injection pump. I'd pull the water pump and equipment off the front f the eng then pull the timing cover, it can be done with out removing the inj pump drive housing or pan but becareful and have a look see. If you need to my email should be open drop me a line. But if not I keep an eye on here. David
Bob
09-23-2006 17:48:24
As David said, there's no timing chain, only 2 timing GEARS.
David A. Hodson
09-23-2006 17:42:07
never seen a chain in a 6.9L or a 7.3L and sadley enough I've seen a few from the early one to the last. darn good engine will still pull like a mother with a cracked head and 2 cylinders with blowed (totaly) intake valve seats but don't ask me how I know this. David
mrn
09-23-2006 17:50:43
 Re: OT - IH 6.9L Diesel V8 (Early 80's) in reply to David A. Hodson, 09-23-2006 17:42:07
Dave,
I posted for a friend who bought (cheaply) an IH rollback with a 6.9L diesel that the previous owner said had a broken timing chain, I don't know anything about 'em myself, sure sounds like you do - so what would cause the cam to stop turning? Is the timing is completely gear driven?
Thanks for the help.
