Tractor Talk Discussion Forum
1965 case 530
scott hall
09-26-2006 18:56:12
I recently purchased a 1965 Case 530 c backhoe loader. I have alot of questions on it, But mainly wondering the weight of it for transport, and the value of it.I think I got a good deal, although it does have a couple problems. luckily I got the parts manuals with it.it runs and digs though no brakes.Would appreiciate any input. SCott
Mike Veen
09-26-2006 19:47:19
 Re: 1965 case 530 in reply to scott hall, 09-26-2006 18:56:12
9,000 lbs if it's diesel. Brakes,just loosen up the adjustment,then take the side covers of the brake.If there is a bunch of goop in there you need to replace the seals.Sometimes you can degrease them clean them real well with brake clean and that might help if the seals are not leaking to badly (for awhile).Adjust them back up when your done.
Scott Hall
09-27-2006 20:48:59
 Re: 1965 case 530 in reply to Mike Veen, 09-26-2006 19:47:19
Thanks for the reply. My tractor is gas, so I assume its slightly lighter. Thanks for the input. I will check for contaminated brake shoes/pads. Thanks again!
If you have any other in put, it would be greatly appreciated.
Mike Veen
09-30-2006 07:28:00
 Re: 1965 case 530 in reply to Scott Hall, 09-27-2006 20:48:59
Just put a new crank in mine ,got the engine in last night ,about a hour to do that.Today I"ll put on all the bits (starter,rad etc).Then cross my everything and see if it goes once again.I know it will ...maybe.Email me if you need more info.
