Tractor Talk Discussion Forum
lacquer thinner
Don c
09-28-2006 09:59:31
Garage has limited heat, only when I am going to work or putter around I will turn furnace on. Every year about this time I must gather up all freezable material and put it in my basement on shelfs. I use lacquer thinner for some prep work on different metals and was wonder if it will hurt it to be in the cold, the coldest I have seen it in there is 28 degs. Live in Western Pa. 3 miles from W.Va. and the Ohio river. Thanks for all and any replies. Don c
B-maniac
09-28-2006 18:19:27
 Re: lacquer thinner in reply to Don c, 09-28-2006 09:59:31
I'm sure you weren't looking for an education on laquer thinner. The answer to your question is NO,it won't.
W4
09-28-2006 17:40:15
I used lacquer thinner on the job for 40+ years. It is dangerous to store it too long in metal containers as they will rust out and spring a leak.Take that into consideration when picking a storage place for it even in warm weather.
chiefrunamuk
09-28-2006 13:18:48
Don; In my shop no heat at all, put all paint,grease, spray cans of solvent,and silicone in an old refrigerater with a 75 watt light in a fixture in the bottem, ain't froze yet, makes the grease gun work better too. Ken
rustyj14
09-28-2006 10:16:41
Don't worry about laquer or enamel thinner/ reducer, mineral spirits, etc. about cold weather.! Do put any liquid paints in the warm areas for winter! Any carb cleaners, engine cleaners, wd-40, penetrating oils, aren't affected by cold weather. gasoline should be treated with Sta-bil for winter use/ storage, but the vote is still out on that. Some say "yes-use it." Others say "No, don't use it!" Being an independent cuss, i use it, and everything starts right up in spring!
jmixigo
09-28-2006 10:09:24
Won't hurt thinner a bit. Don't even keep that stuff in the same building if you use open flame heat, though it won't hardly freeze, it has a lower flash point than gasoline.
Jimmy King
09-28-2006 11:43:10
 Re: lacquer thinner in reply to jmixigo, 09-28-2006 10:09:24
Back in 1967-1971 I worked for the NCR Corp. We had a spray bouth with a dial on the sprayer that said solvent, or lacquer thinner. The oil we used on cash registers would turn to varnish after years of using it. The bouth had a big exhaust fan. I was using lacquer thinner one time and I got on one heck on a high, be careful using it.
GeorgeH
09-28-2006 15:15:22
 Re: lacquer thinner in reply to Jimmy King, 09-28-2006 11:43:10
Jimmy, was that in Dayton, OH? Go down to Brown street occasionally for ribs.
Jimmy King
09-29-2006 01:54:55
 Re: lacquer thinner in reply to GeorgeH, 09-28-2006 15:15:22
No I worked out of the Springfield,MO branch I don"t remember the branch No. I never did make it to Dayton, I went to school twice 3 months in Memphis, and 6 months in Denver I was with the co for just over 4 years, then came back to the farm.
