Tractor Talk Discussion Forum
Off Topic - Remington 1100
dhermesc
09-29-2006 12:22:36
I looking at buying a used 1100 Remington Shotgun. On the side of the barrel it is marked 3" shells, does this mean it will only take 3" shells or will it fire 2&3/4" and 3" shells? Being an automatic I thought it might be more sensitive the ammo. I know on every other shotgun I've ever seen it says 2&3/4" and 3" shells.
phil lowe
09-29-2006 20:18:04
 Re: Off Topic - Remington 1100 in reply to dhermesc, 09-29-2006 12:22:36
I concur with the others 1100 doesn't like the "S$%t" Shells as we call em up here ,most times won't eject,,but it willtake both 2 3/4 and 3".and anyone out there got any Mossberg 500 stocks I'm looking ,,E-bay got some ,but I'm up here in Canada and most won't ship "Gun" parts up here!!!!..only month left till bird season and I'd love to get my old mossberg up and shooting ,,,broke the pump stock apart last winter !!!
Ryan - WI
09-29-2006 18:04:12
The people here would know. Post it in the discussion forums.
Bryan in Iowa
09-29-2006 18:00:25
I have an 1100 magnum, 3 in ,,it will shoot 2 3/4 fine long as you keep it clean . Some off the really light loads maynot eject all the time . But i usually shoot heavy 2 3/4 hunting loads .# inchers just hurt too much anymore ,,must be getting old,,,or trying to talk myself into a Bennelli ??? lol
SuperHank
09-29-2006 13:00:07
They will shoot 23/4 inch shells but you will have problems with anything less than 3 1/4 dram equivalent powder. You probably could reload some good 23/4 inch light loads if you feel like getting into reloading. Make sure the o-ring is kept clean. It is under the fore end and the tube has to be kept clean.
John (MO)
09-29-2006 12:27:43
Hard to say, there were some early ones that didn`t do too well with lite loads. If possible take 3 lite 2&3/4 inch shells, load her up and see that they cycle the action ok. Wear and dirt can also make them a little picky. But if all is well, they are great guns.
Maine Fordson
09-29-2006 13:53:26
 Re: Off Topic - Remington Shotguns in reply to John (MO), 09-29-2006 12:27:43
Since we"re off topic and on Remington shotguns, perhaps somebody out there knows the answer to this: Will the butt stock from a Remington 870 12-gauge fit a 16-gauge 870 Wingmaster shotgun? (And is there a difference between the stocks on the Wingmaster and the Express?) My uncle gave me the gun years ago but I haven"t used it much because it doesn"t fit well -- he sawed a couple of inches off the buttstock because he has short arms. I have the exact opposite problem: longer-than-average arms, and I"d like to get a replacement stock for it (walnut to match the original) so I could be comfortable using it (and be able to hit the broad side of a barn, as I tend to overshoot with it). Around here, 16-gauge shotguns are not all that common, and I wonder if the receiver will accept the stock from a 12-gauge. Thanks for any light you can shed on this matter.
-- Maine Fordson
KENT
09-29-2006 19:09:53
 Re: Off Topic - Remington Shotguns in reply to Maine Fordson, 09-29-2006 13:53:26
I SEE STOCKS FOR 870'S ON EBAY AT GOOD PRICES---HTH
KENT
Larry from md
09-29-2006 15:41:53
The stocks are supposed to be the same between 12 and 16 gauge. One of the 870 versions did have a differant stock,but it would fit all the 870's. I am much better with tractors than guns so hopefully someone can confirm this.
