Tractor Talk Discussion Forum
Machine Work Help
kopeck
09-29-2006 14:58:06
I'm trying to estimate what it's going to cost to rebuild my little Kubota D-600.
I've got the parts priced out but I didn't have enough time to contact the local machine shop before they closed for the weekend. There are four main bearing surfaces, and three rod bearing surfaces and they would probably be machined down .2 mm.
The only variable here is that the rod bearing surfaces might still be with in spec (I spun a main bearing) so there's a possibility that I would only have to have the four mains turned.
I know that prices can vary, but I'll I'm looking for is a ball park figure and thought maybe someone had been to the machine shop recently.
Thanks!
K
banjo
09-29-2006 21:51:39
 Re: Machine Work Help in reply to kopeck, 09-29-2006 14:58:06
I had a crankshaft ground for a super A.$65-$75 was 2 places i priced. did the main and rod journals.This is in OKLA.
