Tractor Talk Discussion Forum
Mitsubishi D2000 24hp
d arnold
09-30-2006 20:08:39
just bought rebuilt tractor...everytime runs about 10 - 15 min and overheats...water pours out over flow and temp screams....what's up?
vally farm
10-01-2006 19:34:32
 Re: Mitsubishi D2000 24hp in reply to d arnold, 09-30-2006 20:08:39
I,m no expert, but go to tractorbynet.com They have a whole forum for Mits. Also, if it is a thermosyphon sys. they say to run 40% coolant/60% water for best effect. Also, you may be filling her too high. Try to only go about 1-1.5 inches above the core and see if this helps. Good Luck.....Mike
oldcraneguy
10-01-2006 06:28:05
Id check the obvious first, fan, belt, shutters, (if applicable) then crank it cold with cap off set throttle about a third watch for water momvement in radiator, if as it heats up you dont see flow pull the thermostat and try it without one, if it cools ok then replace stat. If you do see momvement watch for bubbles (and hope you dont see any) if you do youve got head,gasket,block probs if thats the case Im hopin for warranty. One other thing Ive seen is the suction hose collapsing at higher RPM's so take a peek at it while at speed...hope this helps
