Tractor Talk Discussion Forum
Hercules starter
Dale B
10-01-2006 19:11:37
I have an inboard boat motor made from a 2 cyl. NXB Hercules engine. It requires a three hole starter with about ten teeth meshing forward, probably an inertia type drive I was thinking of the starter in an L or LA John Deere might work . Is anyone familiar with that starter? I don't have a core or the original starter to match up to.
John Stanbarger
10-02-2006 11:07:01
 Re: Hercules starter in reply to Dale B , 10-01-2006 19:11:37
Is this the type of starter you are looking for?
third party image
Glen in TX
10-02-2006 07:09:35
The JD L,LA,LI used a Delco 1107036 starter if that helps. Not sure if it would fit yours as many marine application engines use different starters.
