Tractor Talk Discussion Forum
Fuse wire
Vernon Fisher
10-03-2006 09:56:58
I have a Super A Farmall Tractor and I need to know where the fuse wire hooks to. Just got the tractor and I'm trying to get the wires right on it. The wire that runs from the fuse on the tractor is missing and I dont know what it attaches too. Thanks in advance for your help.
Bob M
10-03-2006 11:44:59
 Re: Fuse wire in reply to Vernon Fisher, 10-03-2006 09:56:58
Vernon - The quick answer is "it depends..."
If the tractor has an original style 4 terminal regulator the fuse supply should be connected to the regulator "L" terminal.
However if it's got only a 3 terminal regulator or has an alternator conversion simply connect the fuse wire to the ammeter post that's NOT connected to the battery.
A simple test: After you get the fuse wire connected turn on the lights (presuming the lights work) or ignition without starting the engine. The ammeter should indicate discharge (should deflect to the left of 0).
