Tractor Talk Discussion Forum
AC D19 with JD turbo!?!?!?!? HELP
Efcattle
10-04-2006 07:37:54
Hi, Have an elderly farmer friend (90 years old) with a D19 he bought years ago used from a JD dealer. The turbo which is a JD is leaking oil like a sieve.
A new one is over six bills. Can the turbo be removed and still have a usable tractor? Any advice either for removal or rebuilding the old turbo would be appreciated.
Thanx, EF
James2
10-04-2006 07:55:06
 Re: AC D19 with JD turbo!?!?!?!? HELP in reply to Efcattle, 10-04-2006 07:37:54
Yes you can take off the turbo, just be sure to turn the fuel pump down so that you are not over-fueling the air supply. Probably expect to loose 20% power. Don't try to rebuild the turbo at home, too precision. A $600 turbo isn't too bad, the $1000 ones make me wince. Might be able to get an acceptable match at a tractor salvage yard.
EFcattle
10-04-2006 08:29:04
 Re: AC D19 with JD turbo!?!?!?!? HELP in reply to James2, 10-04-2006 07:55:06
Thanks James2, Sounds like it will be a D17 with out the turbo, had not considered turning down the pump either. Are you familiar with these pumps? My home shop includes a complete machine shop with a CNC machining center, so precision does not concern me, just never had on of those beasts (turbo) apart before. Asking lots questions before have to buy him a new tractor! :-) We run gassers here on the farm. My diesel experience is limited to my Belarus tractor, which I will have tackle the pump at some point. Just have to keep the pump oil changed and she runs for a bit. Overall it has been a decent tractor.
