Tractor Talk Discussion Forum
Hydralic control valve
B Woodworth
10-05-2006 08:35:32
What would cause a by-pass in a two handled control valve on a front end loader.The lift handle works great but the tilt handle will not hold its position when loaded.Can this control valve be adjusted to hold more weight? Is there an adjustment screw to adjust the flow. This is a reconditioned control valve.
R Corkum
10-05-2006 15:27:15
 Re: Hydralic control valve in reply to B Woodworth, 10-05-2006 08:35:32
Did you check the loose nut behind the wheel? Ha! Ha!
glennster
10-05-2006 10:24:07
had another thought, maybe the new valve is bad, try switching the hoses, plumb the bucket control to the loader lift valve and vice versa and see if the loader creeps down instead of the bucket. if it does, the valve is bad, maybe an o-ring or seal.
glennster
10-05-2006 08:43:50
you may want to check if the tilt cylinders have a blown seal. the tilt on my m did that, i swapped out the valve thinking it was bad, but it still did it. see if the hydraulic fluid leaks back when the cylinder is tilted.
b woodworth
10-05-2006 08:51:49
 Re: Hydralic control valve in reply to glennster, 10-05-2006 08:43:50
this problem just started when i replaced the new control value.thats why i was wondering if there is a ajustment
Allan In NE
10-05-2006 08:46:57
I agree with Glen,
9 times out of 10 a cylinder will be leaking by.
Allan
