Tractor Talk Discussion Forum
OT--Stack temps in outdoor wood furnace
wisc dave
10-05-2006 12:40:00
I have a homebuilt outdoor wood furnace, the combustion chamber is approx 36 in. dia and 42 in. long with 8in. stack, 3 inch water jacket. Forced air for combustion with aquastat to control the fan....you guys with store bought furnaces....what temps are you seeing in your exhaust stack? (I am trying to pick a happy medium for the draft control. ) Thanks in advance.
BillyinStoughton
10-05-2006 13:20:42
 Re: OT--Stack temps in outdoor wood furnace in reply to wisc dave, 10-05-2006 12:40:00
You are talking about two entirely separate pieces of equipment I'm afraid Dave. A gas fired furnace like what is typical in Wisconsin is going to be of the 90% efficiency type and vented in Schedule 40 PVC. Stack temperatures on a 90% piece of equipment are only going to be in the 110-115 degree range (since they have both a primary and secondary heat exchanger). There are also 80% efficient furnaces in the area (though they are becoming less common). An 80% furnace with a power ventor is gonna have a stack temperature in the neighborhood of 180-190 degrees (you don't want an 80% to vent much cooler than that since it could possibly cause condensate in the metal venting and promote corrosion).
Now down to your outdoor wood boiler. The first thing to note is that the stack temperatures are going to be dictated by the return water temerature. The cooler the temperature coming back, the more temperature differential you have, the more heat transfer is possible. That being said, most solid fuel boilers / furnaces (depending on the type of wood being burned)...you are going to get you in the 600 to 750 degrees range.
Billy
wisc dave
10-05-2006 19:44:12
 Re: OT--Stack temps in outdoor wood furnace in reply to BillyinStoughton, 10-05-2006 13:20:42
Billy, sorry I mistyped..I meant to say anyone with a store bought outdoor wood furnace please tell me the preferred stack temps. But you just did...thanks.
wisc dave
10-05-2006 19:44:01
