Tractor Talk Discussion Forum
Tractor Wheel Weights
Reverend Brian
10-05-2006 16:59:50
Hello I have a Fordson Super Major tractor which i just overhauled the engine on. Since i rebuilt the engine and the fuel injection pump the tractor has tremendous power. It seems to have more than necessary as it pulls the front end up off the ground everytime i drag something with it. I recently pulled a large log up hill and when i topped the hill the front end was high in the air. Would putting wheel weights on the front tires stop this problem. The tractor already has a large front end loader on it. Any reccomendations would be appreciated. It has scared me a few times lately. Thanks.
Leland
10-06-2006 06:18:30
 Re: Tractor Wheel Weights in reply to Reverend Brian Jenkins, 10-05-2006 16:59:50
You sound like you really lack the experiance to be operating a piece of equipment such as this , you are trying to pull to much with this little tractor and define large log ? you probley should not try and drag anything over 12" up a hill with this small outfit . but you sound like a person that would not listen to others to save your own life ,but if I were you I would pull smaller logs or buy a larger piece of equipment that can safely handle this job . I have saw the end results of people doing this and have had to help lift a tractor off a corpse more than once thru out the county good luck .
Carl NY
10-05-2006 19:03:16
If you are lifting the front wheels off the ground and have a front loader you must be hitching your log too high with the 3pt. hitch. Hook it to the tractor drawbar and keep the loader bucket as close to the ground as possible. You are flirting with disaster.
Dave Sherburne NY
10-05-2006 18:59:53
third party image
What ever you are hitching to on the tractor is to high. If you have an 11 hole drawbar on the liftarms make sure the lift arms are down when pulling. If you have a drawbar bolted to the bottom of the rear axle, turn it over so the hitch point is lowest.
Does your tractor hitch look like the one in this picture?? I hope you are not hitching to where the top link is supposed to hook, above the axle, you'll get killed
Steve From Arkansas
10-05-2006 18:46:05
Several years ago when my dads biggest tractor was a 2N I was plowing with a 2 bottom plow. Caught a big root from tree that I was no doubt to close to. The little Ford reared up bent the top link into a U before I could clutch it. I'm not sure just having an emplement on the back will prevent a tractor from going over in every case. I'm sure we had a little larger tire than the tractor came out with. Also a heavier top link would have been nice.
Hear in Arkansas I have seen the highway department run a cable from the front of the tractor, I assume it to be attached to the front axil, then it is attached to the drawbar and it hung under the tractor. I understood it was so that if they had to pull each other out of a wet spot, part of the force was place on the front end to keep it down. Has anyone seen this or know why that would not work.
phil lowe
10-05-2006 18:43:51
I've got no weights or loader on my ford 3000 and use a norse logging winch to haul logs with ,,,YUP IT GETS UGLY sometimes ,,gotta keep your center of gravity low ,,only lift high enough so's you don't fetch ,up ,First item I put on my tractor was a roll bar..I gotta get something on the front to help counter weight on the back ,,,I find now that I KNOW it's gonna lift I can anticipate and drop hitch low as she'll go ,,Still no fun ,,Be careful everyone...
JGarner
10-05-2006 17:54:28
When we were pulling stumps or something heavy like logs Dad always made sure we had the 3pt disk or blade on the back and only lifted off the ground about a foot.
If the front did raise up it would only go as far as the implement on the back would allow it before it hit the ground in the back. We NEVER towed anything without an implement on the 3 pt.
Billy NY
10-05-2006 17:47:11
One of my cousins was killed recently when the tractor went over backwards, they were trying to tow some other piece of equipment out of the muck.
I know there are ways to cheat with a tractor, towing things like logs and other heavy things, and a lot of people do it, each to their own, it's still a dangerous thing to do, if that log were to bind up on something, and your front axle is already off the ground, things can get out of hand quicker than you can react to it. I've tested my old 850 ford on a few things, seems the wagner loader certainly helps add weight to the front, and hitching below the axle helps. I've towed a few small logs up hill on occasion, although it seems to handle them well, it is still a stressful ride, so I kinda refrain from doing it, never know, get careless one time, don't take much,
Bob N.Y.
10-05-2006 17:46:43
What are you hitching to on the tractor?
Ken Crisman
10-05-2006 17:28:06
Since you have a loader on the front of it , a load of dirt in the bucket would amount to alot of weight . Man I would think the loader would be enough itself . Try my method . Be careful & God bless . Ken
