Tractor Talk Discussion Forum
Kubota L245DT
Brett Goyer
10-06-2006 14:13:21
was looking for some help,was wondering if anyone knows if and where the hydralic filter is on the fender it shows the location but i can't figure out where it is by the picture(not very descpriptive) i think it needs to be cleaned/changed because the hydralics are very slow and the pump is whining This tractor runs off the gear lube in the tranny case
Norm Maul
10-09-2006 15:45:05
 Re: Kubota L245DT in reply to Brett Goyer, 10-06-2006 14:13:21
Hi. I have one of these also, and it also had a whining pump and slow hydraulics. The filter is in the transmission case towards the rear on the left side. It has a rounded football shaped cover with two bolts on the 'points' of the football. It's around 2 inches long. It's spring loaded, the spring holding in the filter. It appears to be a permanent washable screen type filter. I washed mine in gasoline and replaced it, but it plugged up again very shortly, although it was clean and the fluid was clean. It seems like the filter media behind the screen outer portion is swollen up and won't let hydraulic fluid through.
Hope this helps.
By the way, do you know where to get a new one?
Brett Goyer
10-09-2006 16:11:29
 Re: Kubota L245DT in reply to Norm Maul, 10-09-2006 15:45:05
sorry Norm Maul i don"t know where other than a Kubota dealer?
Vacherie
10-06-2006 15:02:01
I don't know if the L245DT is the same as the L245 but on the L245 i also had difficulty finding the hydraulic filter. On the L245 it is on the left side of the tractor under the seat. The way I remember it is had two bolts holding it in.
doogdoog
10-06-2006 14:51:28
Aloha, Trace out the hose. Not much help, but that's a start until someone can pinpoint it for you. TIA
Mahalo,
doogdoog
pjstanley@floydboe.net
03-05-2007 10:46:22
 Re: Kubota L245DT in reply to doogdoog, 10-06-2006 14:51:28
Has anyone replaced the pto shaft in the Kubota L245dt? I have bent mine and need to replace it. I think that I have to break the tractor at the gearbox, but I am not sure. The owners manual does not have specifics. Any and all help is greatly appreciated.
