Tractor Talk Discussion Forum
massey3165
sailor13
10-08-2006 09:35:38
I have MF 3165 probably 40 years old.(gas) My problem arrived yesterday when 3-point hitch stopped working. The arms are stucked in middle position and won't go up or down, even under pressure. Hydraulic system does not respond to either Draft Control Lever nor Position Control Lever. I had similar problem a few years ago when the arms were just hanging down and would not go up. Somehow the problem corrected itself over night and everything functioned well until now. If there is anyone out there that could help, your advice would be greatly appreciated.
Turke Bros. Farms
10-08-2006 11:54:38
 Re: massey3165 in reply to sailor13, 10-08-2006 09:35:38
First off check your fluid. Are you getting pressure to the top? Get a manual for the tractor, there are some pressure tests you can do to see if the hyd. pump is working. Most likely its the pressure releif valve, and if its a MULTI-SHIFT, the dashpot control valve. Get the manual and do some pressure tests and give us another post.
