Tractor Talk Discussion Forum
I MUST BE STUPID!
Turke Bros. Far
10-10-2006 10:59:22
Why is it every time i buy a tractor, I get it back to the shop to find it needs tires. I picked up a old John Deere B, flywheel start. It has one 1950s whitewall, one two rib steer, one Goodyear rear, and one Firestone rear that has a hole in it i could stick my arm through! Im starting to know my tire guy so well i know his wife and kids names. This aint good, do any of you guys have the same luck?
iowa_tire_guy
10-10-2006 17:26:20
 Re: I MUST BE STUPID! in reply to Turke Bros. Farms, 10-10-2006 10:59:22
I am really not seeing a problem here. Can someone explain it to me?
ITG
Aaron Ford
10-10-2006 17:11:51
Who would sell a tractor with good rubber? The only reason I can see is if something else is wrong with it.... Bad enough that it can't wear out the tires.
Every tractor on eBay seems to have car tires on the front. Mine was no exception. It had good rear tires, but it had a bad hyd pump, broken bottom arm mount, trashed spindles, destroyed motor, no seals, bad brakes, and a thrashed body w/rust. It didn't have a seat, which didn't matter cause I already lost my a**.
Feel better yet?
Aaron
Puffie40
10-10-2006 12:30:40
Try looking at crawler tractors. Most have the undercarrage run right off them.
GeorgeH
10-10-2006 12:20:19
If buying tractors needing tires makes us stupid, then we all would be.
Mike M
10-10-2006 11:47:29
I always figured anyone can buy one ready to go !!!! So I get the ones nobody wants and fix them and then get more money in them but it's spaced out over time and doesn't seem as bad.
steve from mo - dangit!
10-10-2006 11:25:33
 Me too. in reply to Turke Bros. Farms, 10-10-2006 10:59:22
I always buy rental houses that need new roofs.
Brad in WI
10-10-2006 11:25:05
It can be worse. I bought a Farmall MD with a seized engine. Total Rebuild Then I buy a Farmall H with the engine in a box. Total Rebuild I also have a 560D with a seized engine waiting for a total rebuild. I wish I could get by with only tires. LOL Brad
Brian in NY
10-10-2006 11:22:47
I always try to buy tractors with usable rubber....but there could be worse things than needing tires, right?
Good luck with the new tractor!
How about a photo of it?
steveormary
10-11-2006 06:39:22
 Re: I MUST BE STUPID! in reply to Brian in NY, 10-10-2006 11:22:47
At least with bad tires you can see some of what is wrong with the tractor. I usually get the ones that have cracked heads and bad TA"s.
When a 656 wont pull 3-14"s you know you are in trouble.
steveormary
