Tractor Talk Discussion Forum
power steering fluid
al bane
10-11-2006 17:51:16
I have a Ford 860 and need to add some power steering fluid. What can I use or what do you use for power steering fluid, I"v been told some use hydraulic fluid and others use transmission fluid.
al bane
10-12-2006 05:36:07
 Re: power steering fluid in reply to al bane, 10-11-2006 17:51:16
OLD---how did you drain your power steering fluid--I think I may need to do that--AL BANE
jmixigo
10-12-2006 06:20:42
 Re: power steering fluid in reply to al bane, 10-12-2006 05:36:07
TO ME the easiest thing is to jus unbolt it an have a 5 gal bucket sittin there waitin to pour it in. Leave the lines hooked up an tilt. If theys a pile a crud in the bottom rinse as needed with min spirits. Change the filter fore you refill.
al bane
10-12-2006 08:14:27
 Re: power steering fluid in reply to jmixigo, 10-12-2006 06:20:42
My tractor didn't have a filter on it when I bought it in the power steering reservoir and I went ahead and bought all I need to install a filter.I have the retainer ,the retainer spring, and the spring seat. the retainer has a half hook on the bottom of it---what does it hook to , to keep the filter in place>?
old
10-11-2006 19:12:37
I have always used dexron tranny fluid in my power steering on my 841, I tried the hyd fluid but it didn;t work well and I had to drain and flush the system because of it.
souNdguy
10-11-2006 18:16:19
I'd really try to add what was in there.. however.. generically, UTF, hydraulic fluid, or power steering fluid ( atf ) would probably all work.
you could always drain and go back in with UTF
Soundguy
