Tractor Talk Discussion Forum
Let the wrenching begin!
Sloroll
10-12-2006 06:11:59
Time to line up the winter blah projects. I have several this year. I rarely get a shiney pretty tractor. This one is in great shape though. Doug in IL Found her for me. 29 Allis 20-35. If I'm not side tracked it will be running smooth in a shiney Allis green and on rubber by early summer. (maybe).
third party image
Sam (MO)
10-12-2006 11:26:52
 Re: Let the wrenching begin! in reply to Sloroll, 10-12-2006 06:11:59
Heck I'd like to see some more Pic's of that shop...
Sloroll
10-12-2006 12:11:50
 Well, here is the left side Sam in reply to Sam (MO), 10-12-2006 11:26:52
Ask arround it can get pretty messy. :? )
third party image
Nebraska Kirk
10-12-2006 19:38:39
 Re: Well, here is the left side Sam in reply to Sloroll, 10-12-2006 12:11:50
What make is that biplane?
Sloroll
10-12-2006 21:04:55
 Re: Well, here is the left side Sam in reply to Nebraska Kirk, 10-12-2006 19:38:39
1941 Meyers OTW
jake4
10-12-2006 08:22:08
Sounds like that clutch might be rusted to the flywheel[Fords are really bad for this] I clamp the clutch pedal down, put the trans in 1st or 2nd and tow a short distance if rusted should break loose. Worth a try.
Doug in IL
10-12-2006 07:45:01
It's sure good to see that tractor in nice surroundings. It looks so much better there than where I first saw it! Good Luck with it. And, yes, please post some pics as you progress.
jubilee johnny
10-12-2006 06:42:03
I've got a 41 jd h that is my winter project, that is after I finish the jd/vanbrunt ff drill, and get my 45 loader attached to the 70, new rear tire on the b,well, you know how it is....
jmixigo
10-12-2006 06:26:25
Wow that thing is straight!!
Don't find many real werkin tractors that complete either.
Maybe it jus looks better than what I'm used to cuz the tires ain't flat.
Nebraska Cowman
10-12-2006 06:23:56
That looks like a fun project. Someday I want to do a steel wheeler again. I have the stuff to do a wide-front H if I just had the gumption.
RustyFarmall
10-12-2006 06:22:10
That tractor could be a lot of fun just the way it is, but would also be quite interesting all shined up. Be sure to take pictures as the work progresses.
Harley
10-12-2006 07:42:17
 Re: Let the wrenching begin! in reply to RustyFarmall, 10-12-2006 06:22:10
Well I just found out last night from one of our esteemed mechanics on the site that that cheap 706D I brought home will probably need a clutch pretty soon, or sooner. Got it in gear yesterday and couldn't stop it. Pushed the clutch in and it just kept going. Had to kill it with the fuel lever to get it to quit. Probably not a good thing in a close situation. Sooooo o that means a split. Thank goodness for concrete shop floors. Harley
Jimmy King
10-12-2006 09:27:25
 Re: Let the wrenching begin! in reply to Harley, 10-12-2006 07:42:17
Harley, I have put a clutch in my 756 and 706 it"s not too bad of a job.
Mike (WA)
10-12-2006 08:27:10
Before you split it, try taking the starter off and clamping the clutch pedal down- then, you should be able to work a blade between the clutch disk and the flywheel, rotating and "worrying" it until it comes loose.
