Tractor Talk Discussion Forum
8N 3-pt hydualic's
small farmer
10-12-2006 18:01:24
My 1949 8N was in storage for 7 yrs, 3 pt arms was stuck in the up position, took top cover off, cleaned piston,check rings, cleaned everything rein-installed top cover, with PTO running clutch out , no lift on the rockshaft,has plenty of fluid, help!!
Thanks
Dachshund
10-12-2006 18:20:28
 Re: 8N 3-pt hydualic's in reply to small farmer, 10-12-2006 18:01:24
Mine did the same thing.
I put on the 11-hole drawbar between the arms and kept working the control handle back and forth with me on the drawbar. You can also do this with a small implement ( blade, caryy-all, etc). I just found it safer with just me. Keep working it and it will eventually work itself loose.
