Tractor Talk Discussion Forum
piston material
todd99
10-16-2006 15:37:00
My father and I are restoring an old tractor and have a difference of opinion in what they are made of I say they are made of cast material he says no. Can anybody help me? The tractor is a farmall H. Thanks Todd
RustyFarmall
10-16-2006 17:10:51
 Re: piston material in reply to todd99, 10-16-2006 15:37:00
The pistons in an H are made of cast aluminum.
champspa
10-16-2006 16:20:10
some are cast iron others are aluminum
coflyboy
10-16-2006 19:51:17
 Re: piston material in reply to champspa, 10-16-2006 16:20:10
I've seen where valves break off in airplane engine cylinders and the piston beat that hard steel valve into a ball and never break. They gotta be tough (I know that didn't answer the question).
Aaron Ford
10-17-2006 07:57:07
 Re: piston material in reply to coflyboy, 10-16-2006 19:51:17
This was 1991 and the details are hazy, but here goes.
A lady came into our garage with a notable engine miss. TBI 2.5L Olds, I think. No compression on one cylinder. Fuel and spark were fine. Pulled the head to find the piston was in the pan ground up with a good section of rod still attached. I have no idea how it ran, but it came in under it's own power. She had said it made some noise.... Aaron
37 chief
10-16-2006 21:31:16
That sure must have made some noise, if you could even hear it. Stan
