Tractor Talk Discussion Forum
3 PT LIFT ON 40 JOHN DEERE
HOMERD
10-16-2006 15:50:41
A FRIEND HAS A 40 AND THE LIFT WILL NOT STAY UP, WILL NOT RAISE BY THE TRACTORS HYDRULICS. WHAT COULD BE THE PROBLEM?
jCarroll
10-16-2006 19:14:47
 Re: 3 PT LIFT ON 40 JOHN DEERE in reply to HOMERD, 10-16-2006 15:50:41
First thing to check is the hydraulic oil level.
If it's full, crack a pressure line fitting ansd see if it squirts.
If it does, you need the Service Manual for what comes next.
lgc
10-17-2006 07:49:14
 Re: 3 PT LIFT ON 40 JOHN DEERE in reply to jCarroll, 10-16-2006 19:14:47
If it has dual controls, one thing to check. Under the left side of the seat is a lever that should be flipped forward. The lift arms should then be pinned together, and only use the outside lever. THe inside one should be left in the up position.
