Tractor Talk Discussion Forum
tractor running out of power
dave bowdle
10-16-2006 18:29:09
i have a 1 owner jd 4430 that is giving me fits . it will run just fine for 30to 60 minutes then seems to not be getting enough fuel . it was ouerhauled 1000 hrs ago . i've changed fuel filters twice ,cleaned sediment bowl ,replaced a kinked fuel supply line,completely drained and blew out the fuel tank .i am using B20 biodiesel but no problems in 3 other tractors and combine please help!Dave
MeAnthony
10-17-2006 05:28:51
 Re: tractor running out of power in reply to dave bowdle, 10-16-2006 18:29:09
Had a GMC truck with a 6.2 did that to me. Would idle forever, but try driving it down the road and you wouldn't get far. Crazy thing was, the LESS fuel in the tank, the FARTHER you could go. Turned out the fuel cap vents were plugged. It would suck to a vacuum, then couldn't draw any more fuel.
Tom in Central Pa
10-17-2006 03:28:27
Check the fuel RETURN lines from the injection pump and injectors back to the fuel tank. If they are not clear, and free flowing, will cause that kind of problem. It"s like a blocked exhaust, will start OK, then slowly die.
Leland
10-17-2006 02:37:50
We had an 8430 do the same it ended up being a diaphram or something in the pump sucking air .
J Schwiebert
10-16-2006 18:50:12
Our 4440 did that the other year pulling wagons. We had to throw the strainer in the bowl on the injection pump away and get a new one. Also does your fuel cap vent O> K.?
jared in wi
10-16-2006 18:42:33
when you are working it, does it smoke any? if so, what color? have you changed the air filters recently? if not replace both the primary and secondary air filters. DO NOT blow them out. if you still have no change in performance, the next things to look at would be the turbo, and a compression check on each cylinder. When the tractor was overhualed, was the head reconditioned and checked for cracks? and was the turbo checked out? was the injector pump and injectors reconditioned?
