Tractor Talk Discussion Forum
4020 12v/24v system
nickg
10-18-2006 20:14:36
I have a 1966 4020 Diesel.I am having strting problems. I have 2 new batteries and new cables. I get about 3 good cranks and that is all she wrote, But as soon as I hook up my jumper cables it fires right up. Could this be a starter problem. I am also confused on how the 12v part of the system grounds so the 12v acc works. Which batt and posts do I need to use to ground it to the frame.
Gerald J.
10-19-2006 08:19:54
 Re: 4020 12v/24v system in reply to nickg, 10-18-2006 20:14:36
The other problem with the scheme is that the generator is only rated to put out 10 amps. Which means it can take more than half a day to recharge from a slow diesel start. When use for utility work there's rarely a half day's work for any start so the generator never catches up.
Gerald J.
John T
10-19-2006 06:27:56
Nick, youre not the first or last guy whose experienced headaches with that 24 volt system. Basically, the Starter and Generator are two wire isolated from frame ground systems. The two 12 volt batteries are joined in series to form 24 volts, and at the mid tie point where they are joined together, that same point is also bonded to frame ground. However, the starter is across the 2 outermost untied terminals, the + of one battery and - of the other, which feeds it 24 volts INDEPENDANT OF AND ISOLATED FROM FRAME GROUND.....
Nowwwww to get 12 volts to operate the lights etc, its still 12 volts from EITHER outermost untied battery post (+ of one - of other) with respect to frame ground, its just that one battery supples 12 volts Negative ground while the other supples 12 volts Positive ground. Those 2 circuits feed up to the light switch and are identified as either A or B circuits and the theory was to balance the loads on the batteries by supplying some lights off the A circuit (one battery) and others off the B circuit (the other battery).
The charging system is 24 volts also isolated from frame ground and charges the 24 volts across the outermost two untied battery posts (+ of one battery - of other) charging the series battery combination both at once.
It happens inside starters that copper brush dust can cause a shorted connection from one of the batteries to frame ground (its supposed to be totally isolated from frame) which can discharge them and its also difficult to keep the loads balanced causing one battery to have to work harder then the other.
When asked about problems with 6 or 12 volt grounded systems like most other tractors we can often help over the net, buttttt ttt your system is too complicated to provide as much help not being there armed with a test lamp and meter, sorry..... ..
As far as charging either battery, you still connect + to + and - to - from a 12 volt charger to either battery, its just that you find on one of the batteries has its - tied to frame and the other has its + tied to frame. Thats the inner tie point which makes up the series connection. Still, its 12 volts from either outermost untied battery post to frame ground, which is how n where n why 12 volt lights or other 12 volt loads worked when fed from the A or B circuits fed up to the light switch. Due to unbalances one batery can run down and if either is bad that seriously affects starting operformance as you are experiencing. Its also best if both batteries are equal in rating and age and condition and often BOTH have to be replaced if one is bad cuz the other one would then be weaker as its older.
Best wishes
John T
Shep Va
10-19-2006 07:03:05
 Re: 4020 12v/24v system in reply to John T, 10-19-2006 06:27:56
John T,
This being said I am becoming less and less of a fan of this system.
What is the recommendation and what is involved in changing this 24 volt positive ground to something a little more user friendly. I would assume the starter needs changed to 12 volt, the generator to an altinator, and the battery cables replaced. What about the gauges and lights if I was to change to a 12 volt negative ground with two batteries??
Does John Deere make a kit to change this system?? I am just trying to learn as much as I can before I decide to change the system and blow something up.
Thanks
buickanddeere
10-19-2006 16:13:04
 Re: 4020 12v/24v system in reply to Shep Va, 10-19-2006 07:03:05
It's 12V negative ground from one battery and 12V positive ground from the other battery. The 24V generator,24V voltage regulator and 24V starter are all isolated from the chassis, even unbolted and hanging free of the tractor but connected by the wires. While 10amp at 24V sound scrawny. It's the same as 20 amp at 12V. Ok in it's day before power eating extra were hung on the tractor. Then again some cheap skates shut off the tractor for the two minutes it takes to open a door or gate. No wonder the battery(s) don't stay charged.
John T
10-19-2006 08:27:45
Shep, Indeed many convert them to a straight 12 volt systems (think Mother Deere has them) and still use the same two 12 volt batteries, but wired in paralell this time, + to +, - to - and the negatives of both attached to frame ground with the + battery post(s) wired to the starter and accessories, and the 12 volt starter is the most expensive item, several hundred bucks. The 12 volt alternator isnt all that expensive as its simply a 12 volt Negative ground and I would use at least 0 or better yet 00 Gauge battery n starter n ground cables.
On the light switch where the two A and B circuit BAT inputs were, they would be tied together with now only one 12 volt + battery source (from where both + are tied in paralell). The lights arent that complicated to change over as they were already for 12 volts its just that some were on the A battery and others the B, but now those are tied and common from ONLY the paralell + 12 volt combination. The gauges may or may not be tricky, but if they were originally configured as 12 volts negative ground (i.e. were fed ONLY from the Negative grounded battery) then they woulndt be any problem.
NOTE Im NOT a New Generation guy and have never done of of these but am knee deep in theory to explain how n why, but you really need to talk to someone who has done this before as far as cost and how much trouble or how complicated it all was !!!!! !!!!! !!!!! ! Buick n Deere and Gerald J and others are wayyyyy more familair with 24 volts and conversions then I would be
Best wishes n good luck, let us all know how it turns out.
John T
Gerald J.
10-19-2006 08:11:39
Deere does sell a kit for the conversion. Round about $600 unless on sale.
It comes with a 12 volt starter, 12 volt alternator and bracket, and instructions. No doubt there is some wiring, though beyond the battery cables to parallel the 12 volt batteries (or use two 6 volt in series like some later tractors) the load wiring should only require hooking the A and B sources to the battery positive.
I think the shop manual shows 12 volt wiring diagrams for the diesels because they came from the factory that way when equipped with a cab.
Gerald J.
Shep Va
10-19-2006 08:54:18
 Re: 4020 12v/24v system in reply to Gerald J., 10-19-2006 08:11:39
Thanks guys, just trying to get an idea of what I am getting into before I decide to change it over. It sounds like it is very doable, just a matter of getting all the gauges and wires right.
I would assume the generator has a voltage regulator somewhere that would need to be removed in favor of a nice delco altinator with an internal regulator.
Bob
10-19-2006 09:11:04
 Re: 4020 12v/24v system in reply to Shep Va, 10-19-2006 08:54:18
Shep,
If you NEED to, or are simply DETERMINED to change it over to 12-Volts, email me, and I will get a diagram to you.
It's quite simple. They use a 12-Volt starter, and an additional solenoid to interface between the key switch and neutral start switch(s)and the solenoid on the starter. A simple Delco 10SI alternator is used.
Cost-wise, you don't NEED a $600.00 kit.
The starter is the main expense, they can be found at rebuilders, etc., for less than Mother Green's price, and the 12-Volt alternator can be had for as little as about $10.00 at a auto salvage yard, to as much as $150.00 for a rebuilt at Deere.
One "issue" is the fuel gauge. It is now supplied from the (+) grounded half of the 24-Volt system, and will be inaccurate on the new 12-Volt (-) ground system. If more accuracy is needed, you'll have to get a gauge, and POSSIBLY a sended for a newer 12-Volt 4020.
bigcoulee@hotmail.com
Gerald J.
10-19-2006 09:54:47
 Re: 4020 12v/24v system in reply to Bob, 10-19-2006 09:11:04
If its like my gas 4020 the sender may be about worn out so it needed work or replacement. I changed my tractor from postive ground to negative ground when I put in an alternator that really charges the battery and the gauge reads. After fiddling with the sender, I keep a 2.5 gallon can in the barn filled with gas for that reserve to get the tractor back to the barn when it runs out of gas. Fortunately I never get more than 1300 feet from the barn and so the exercise doesn't hurt me, much.
Gerald J.
ed1
10-19-2006 06:06:20
Never had a 24v John Deere but allways wondered how they got 12v.
From what you described it sounds like a really bad idea to hook any extra 12v device to that system.
The design is just too complicated - having to worry about balancing everything. Alternating the gandy box on every row between positive and negitive ground ? or the right is positive and left negitive.
A better way would be to use a really heavy duty resistor to drop the 24v to 12v.
JiminIA
10-19-2006 05:48:40
Very commen to have a battery go down and have those syptoms. Check the charging system while you are at it. I can get you a kit with everything you need to convert it to 12v system. Hope this helps, Jim
jdemaris
10-19-2006 05:13:22
That starter needs at least a consistent 18 volts under load to crank properly. As Bob stated - other than the 24 volt cranking system - one side of the tractor is 12 volt negative ground, and the other side is 12 volt positive ground. But - as far as the system working "great" when it was in production - I'd argue that. I went to MANY Deere service schools when those systems were new or recent. Deere had several problems that could not be fixed sucessfully and was constantly coming up with new "band-aids.". #1 problem was the starter itself. For the entire electrical system to work properly - the starter needs to stay isolated or "groundless." But - over time it will develop internal grounds from brush-dust and create havoc. On some systems, a small fused ground wire is used on one battery -and it will blow constantly once the starter develops a slight ground. Also - the higher the voltage - the smaller the wire-diameters. The Delco 24 volt used by Deere had very fine wires in the starter-windings that burnt up much easier than a 12 volt or 6 volt starter. So, starters on such tractors in cold climates had short life-spans. I assume if directions were followed closely -this would not happen. But - how many people - when they need their diesel tractor running - let their starter cool for five minutes after every 30 seconds of cranking? In regard to the two separate 12 volts systems used in the tractor for lights and accessories - it was dependent on a balanced load between both sides. It could not sense and accomodate separate 12 volt demands. Even with small-draw loads - e.g. a 3 amp load from a radio - the system would suffer unless a dummy-load was installed on the opposite side to compensate. We had some serious problems with a few farmers attemtping to use corn-planters with a 6 amp per row draw. When the 24-12-12 system first came out - Deere engineers were bragging about it - saying it was the first of its kind - and custom tailored for Deere by Delco-Remy. I didn't get it then - and still don't. My old Allis Chalmers crawler - circa 1956 - has a non-complicated 24 volt system and has been much more reliable than the mess Deere used.
Shep Va
10-19-2006 05:11:34
I have been working on a neighbors 4020 like this and I thought someone had put that mess togeather. It is just as you describe a 12 volt - 24 volt start with a positive ground. After trying to wire a round bale monitor on the tractor I finally figured out what was going on and got it wired correctly.
Is there any advantage to this crazy system, I can see this being a real problem running negative ground equipment on it and running a danger of shorting something out. Is there an easy way to change the system to a 12 volt negative ground system with two 12 volt batteries?? I would assume you would have to change the starter and rearrange the battery cables, but is there anything else that would get messed up??
buickanddeere
10-19-2006 16:16:53
 Re: 4020 12v/24v system in reply to Shep Va, 10-19-2006 05:11:34
the 12V + , 12V - and isolated 24v system was suposed to to cheaper and simpler than a 24v start/12V run system. Problem is too many tinkerers and too little knowledge. An extra HD relay and 12/24 would have been the answer in hind sight.
MarkB_MI
10-19-2006 03:37:42
The 24V system won't crank if you have one weak battery. This is bound to happen if you run any accessories that draw a lot of current, since the 12 volt accessories will rob charging current from one battery, with the result that one battery is undercharged and the other is overcharged. If you think this might be the case, charge up both batteries separately with a 12 volt charger.
JCKS
10-19-2006 01:28:01
I have a 1966 4020 Diesel that is 24 volt, it has two 12 volt batteries hooked together in series. That is the batteries are connected pos. to neg. The 24 volt regulator is available from Deere fo around $53.00. When I get home I'll check to see if it's pos. or neg. ground. Jim
Bob
10-19-2006 06:38:10
 Re: 4020 12v/24v system in reply to JCKS, 10-19-2006 01:28:01
JCKS,
It's NOT really (+) OR (-) ground.
The midpoint of the system is grounded to the chassis, making 1/2 of the system 12-Volts (+) ground, and the other 1/2 12-Volts (-) ground.
Dan-IA
10-18-2006 21:07:55
Well I'm not much for the green paint, but usually about everything is negative-ground. I doubt you've got a 24v system; I've never heard of it anyway. Usually the batteries are in parallel (+ to +, - to -) to keep the voltage the same and raise (double) the current.
Of course, the older John Deeres (I have an A like this, anyway) were positive-ground. So I can't give a straight answer here. But I suspect in the later models that they would've changed to the more common negative-ground configuration.
Could it be a starter problem? Well, I have an IH 756 with similar behavior. I'm told it could be either bad brushes or a solenoid problem. So, yes, it can be a starter problem. Or it could be a wiring problem. I've seen that a few times, particularly with tractors with a more than a few years on 'em. I like to replace the wiring on my tractors once they start acting up like this.
Just a few thoughts, from one of the 'newbies' on this board. :)
willieinmn
10-19-2006 05:52:09
 Re: 4020 12v/24v system in reply to Dan-IA, 10-18-2006 21:07:55
Dan
Yes, it is a true 24v system,isolated, not grounded, for the starter/generator(or alternator) circuit. Everything else runs on 12v, some circuits neg gnd, some pos. The 24v starter is the same generic Delco that has been in use since around 1940 or earlier on Cummins, Detroit, Mack & the military rigs. The problem with the old systems was the 12/24 relay.When starting, that relay would switch the 2-12v or 4-6v batteries from the normal 12v operation to all in series for 24v to the starter, then switch back to 12v when releasing the start button. The Deere 24/12 system could be compared to the 240/120 panel in your house. Stove, dryer, other 240 appliances are hooked up to line 1 & line 2, isolated from the neutral. 120 appliances & lights are hooked to either line 1 OR line 2 & neutral. If the 120v loads are perfectly balanced, there is actually no load on the neutral.
I know this is clear as mud, but it sort of covers the ground
Willie
Bob
10-19-2006 06:33:32
 Re: 4020 12v/24v system in reply to willieinmn, 10-19-2006 05:52:09
Willieinmn,
There is NO "relay would switch the 2-12v or 4-6v batteries from the normal 12v operation to all in series for 24v to the starter, then switch back to 12v when releasing the start button" used in the Deere system. The batteries are ALWAYS in series, delivering 24-Volts to the starter, and being charged at 24-Volts.
You are obviously thinking of semi trucks and construction equipment that used a series-parallel switch. The Deere system did NOT use a series-parallel switch!
Bob
10-18-2006 21:31:50
Dan,
As an IH guy, you are missing a TREAT, not realizing Deere/Delco came up with a split 24-Volt-12-Volt system for the diesels from the late '50's to the mid-to-late 60's
Nick's correct.
It IS a 24-Volt system. The midpoint of the two batteries is grounded to the chassis, giving (+) 12-Volts for 1/2 of the lights, and (-) 12-Volts for the other 1/2 of the lights.
This system worked GREAT for it's era, but nowadays, trying to operate lots of 12-Volt (-) ground accesories can cause problems with the charging system providing enough current to run the (-) ground loads, as it charges both the (+) ground battery and the (-) ground battery in
series.
nick,
What is the CCA rating of the batteries? Are they both fully charged when you atempt to crank the engine?
nickg
10-19-2006 07:02:11
 Re: 4020 12v/24v system in reply to Bob, 10-18-2006 21:31:50
to answer your question dan yes, both batteries are fully charged and the and the cca is i think around 480. not very much but this is what the deere dealer said goes in
Bob
10-19-2006 07:17:31
 Re: 4020 12v/24v system in reply to nickg, 10-19-2006 07:02:11
The old partsbooks show the 480 CCA battery.
The currently-recommended battery is #TY24341, with 620 CCA's.
nickg
10-19-2006 08:11:35
 Re: 4020 12v/24v system in reply to Bob, 10-19-2006 07:17:31
I looked at the wrong number. I have 620 cca. I also just had my starter tested and it was bad. i am hoping this solves one of my electrical problems. I am still a little confused though on how the 12v side grounds to the tractor frame. My 66 does not have any other wires coming off the batt except the ones connected to the starter and the one that hooks the + of one to the neg of the other. I am sure I have a ground issue do to none of my lights work until I ground the lights to the frame with a short jumper I use for testing
Joe in Ne
10-19-2006 08:50:49
 Re: 4020 12v/24v system in reply to nickg, 10-19-2006 08:11:35
NickG If your starter is bad don"t have it fixed. Just get new kit from Deere. I"ve done it a couple times and is well worth cost. It will get rid of any future problems. Hooks up easy. Should only take a hour or so.
Bob
10-19-2006 08:43:52
Connect the midpoint of the batteries to the chassis with a length of fusible link wire, or a 20 Amp slow-blow fuse.
nickg
10-19-2006 10:20:57
 Re: 4020 12v/24v system in reply to Bob, 10-19-2006 08:43:52
I am not sure what you mean by the mid point of the batt. This electric system on this 4020 is new to me. I had a 4520 a while back but it was already converted and my 4440 is all 12
Gerald J.
10-19-2006 12:28:04
 Re: 4020 12v/24v system in reply to nickg, 10-19-2006 10:20:57
There are two 12 volt batteries connected in series (+ to -) for 24 volts. That junction between them is the midpoint and it gets grounded. How its grounded varies with the tractor vintage. Some have a solid battery cable from each battery to the transmission case, some have a cable from battery to battery with a small fused wire to the transmission case.
Gerald J.
nickg
10-19-2006 13:03:32
 Re: 4020 12v/24v system in reply to Gerald J., 10-19-2006 12:28:04
so what is the best way for me to go about grounding the 12v part? Get a small fuse and ground it to the trans? and does it matter if in the midpoint which battery I ground for the 12V side? Sorry for so many questins I am trying to understand all this and my shop manual and the guys a deere haven"t been very helpful
