Tractor Talk Discussion Forum
Corn and Pellet Stoves
Wrenchbender
10-20-2006 19:37:59
What's the real difference between corn stoves and wood pellet stoves? It seems the corn stove can burn pellets but not vice-versa. What's anyone's experience? Thanks, WB.
65 Oliver 1650
10-23-2006 18:19:45
 Re: Corn and Pellet Stoves in reply to Wrenchbender, 10-20-2006 19:37:59
We bought a corn stove last fall. We love it, I burn about 1 coffee can of wood pellets and 1 handful of oyster shell along with a hopper full of corn, to help it burn great and it helps out with the klinkers. Ours is a US Stove company stove.
Forist NWMa
10-21-2006 15:01:57
i put in a coal stove last year only because i donot have a wood lot. i did a lot of looking around and found out that coal puts out almost twice the btu's of pellets, and i can store the coal out side in the snow ! just bring in a bag the day before i need it and dump it in the stove,and i can run it off from 2 12volt camper batteries with a voltage iverter for a day then just get out my 1000 watt gen for any longer !
Oldmax
10-21-2006 09:00:38
I use a Englander wood stove .the reason I do is the pellet stoves won't operate without eletcric most of the time when you need a backup
the power is off . Some people around here that have pellet stoves buy their pellets in the summer , like I cut Wood this year for next ,not wait untill I need it that way it is dryed out & all you have to do bring it inside .
morningwood
10-21-2006 07:18:03
I purchased a wood burning stove myself a few years ago.I also have easy access to good hardwood to run it on.
I talked to a few people that have pellet stoves and they told me that a major issue with them is that during the middle of the winter they cannot find pellets. I was at TSC last year in January and there were people lined up in the store_waiting_to buy pellets that were being shipped to the store that day. I asked the guy there and he said they running out on a daily basis. Last year was not very cold also. My advice is that if you can afford it, buy all your pellets in the summer so you do not have to wait in line.
If you are in farm country I am sure that you could find a farmer that would be more than willing to sell you some of his feed corn. I am not sure how clean or what moisture content it has too be. You also have to worry about mice when storing your corn.
If I did not have access to wood I personally would have gotten a anthracite coal stove. On a per lb per BTU basis you get the most heat out of lb of coal and you do not have to worry about the mice or a store having it in stock. In the fall time you should be able to get x amount of tons worth of coal dropped off to burn then you would just need to feed the hopper as you would a pellet or corn stove. Harmon and Hitzer ( non - electric ) make some really nice pea / nugget style coal stoves.
Thanks,
Scott
SM in Wi
10-21-2006 06:41:32
This is a good website about burning corn. I bought a pellet stove the other day. I don't have it yet, but i know allot of people who have them, and really like them. Do a search for pellet stoves or wood pellets. You will find allot of very good websites on them. I bought a Glow Boy. Harman is one of the best pellet stoves made, come are hih priced. Gloy Boy is next in line, and are better priced.
farmerjohninpa
10-20-2006 21:47:16
first let me say i have not seen or own a pellet stove. a few nights ago i watched a show put on every monday by a Reading,Pa. based stove dealer on channel 69 and according to the dealer, he stated that a pellet stove,( TO MAINTAIN ITS EFFICIENTCY), must be shut down and cooled off DAILY, so as to clean the burner chamber.that to me would be a nuisance,i have a Alaskan coal/wood burner and all i burn is wood for back-up and aid in economy.
davpal
10-20-2006 21:41:15
Only real difference is that corn has to be stirred to keep from having a klinker form over the fire and snuff it out. Pellets don't do that so they just have an auger that drops pellets in the burn pot with gravity. So if you put all corn in a pellet stove it would keep going out. Pellets in a corn stove would be fine being stirred. It is generally ok to mix in some corn with the pellets though if you want to. They say you can go about 50-50 mix on it. I guess you would have to experiment with the perfect mix.
Jim Broughton
10-20-2006 20:17:47
Wrenchbender; Here in Oregon we use pellet stoves, and they work real well..I installed mine two years ago,when the high fuel oil prices hit.(They're still pretty high) Major problem is if you leave your home or shop for several days in real cold weather, you'll most likely run out of fuel, since most of these stoves will hold only two or possibly three days worth of pellets, at best. Now, my instruction book says that the pellet stove will burn corn, but you need to get the temperature to ignite the corn...doesn't say how this is done! Anyway, check with your pellet stove dealer, and they should be able to advise you. P.S. I find that the pellet stove lowered my fuel costs significantly for the winter season ! Good luck ! Jim B.
