Tractor Talk Discussion Forum
Screw for points
Brian630
10-21-2006 13:34:49
I was just starting to make progress. While trying to get that little screw in the hole that holds the points down, it fell down in an opening. Grrrrr rrrr. Does it have to come out if I get another screw. Feel like I'm taking one step forward and two back. Any advice? Thanks
B-maniac
10-22-2006 13:12:47
 Re: Screw for points in reply to Brian630, 10-21-2006 13:34:49
Hold the magnet as close to where the screw might come out as you can,blow around any openings with high pressure air.Usually it won't take long and you will see a screw sticking to the magnet.
Jim Johnson
10-21-2006 17:19:26
Wow I thought it was a contest. Man am I embarrassed.
Harley
10-21-2006 17:58:09
 Re: Screw for points in reply to Jim Johnson, 10-21-2006 17:19:26
I'm with you Jim, only I never did it for points before, although it might beat curling or shuffleboard. Harley
bill mar
10-21-2006 16:41:11
only screw i ever dropped in a distributor and left in there jammed it and ended up shearing the gear on the bottom of the shaft off.i would remove the distributor and turn it upside down to get the screw out if you cant fish it out.
Maark
10-21-2006 15:00:45
Remove the dist. cap and make notice where the rotor is pointing. Then use a black marker and make a mark on the dist. base and the block. When installing the dist. align the marks along with the original rotor position, you should be okay on timing.
Brian630
10-21-2006 15:25:49
 Re: Screw for points in reply to Maark, 10-21-2006 15:00:45
The cap is already off as well as the rotor and dust cover. Was I suppose to mark something before I took this suff off. SAY IT AIN'T SO. Or is there something I should mark now before I take the distributor off.
What I really need is small magnet like a wire that bends at a right angle to get at the screw. Probably not such thing, but if you have any other ideas let me know. Already tried me shop vac with a section of garden hose attached.
MarkB_MI
10-22-2006 04:09:08
 Re: Screw for points in reply to Brian630, 10-21-2006 15:25:49
Try using a piece of steel wire held against a magnet. The magnet will magnetize the wire.
MarkB_MI
10-21-2006 14:01:58
I'm sure there are a lot of distributors with screws loose inside them, and chances are that no harm will come if you leave the screw in. However, if that screw ever bounces into the flyweights, it can do a lot of damage. I'd sure try to fish it out with a small magnet. If you can't fit a magnet into the hole, try magnetizing a small screwdriver. Chances are that you'll get it with a magnet, but you can always pull the distributor and dump the screw out.
Brian630
10-21-2006 14:10:35
 Re: Screw for points in reply to MarkB_MI, 10-21-2006 14:01:58
I have a magnet rod, but can't get the end in the opening. Do you think it is just below the opening or fell deeper. Don't know if I can find another small screw like that. If I have to take the distributor off, what's involved with that? I see a line running from the top of the carb mount and a mounting nut on the distributor. If I take it off will this screw up the timing? Thanks.
shinnery
10-21-2006 19:44:19
 Re: Screw for points in reply to Brian630, 10-21-2006 14:10:35
Just stick the rotor back on and mark the side of the dist. where it is pointing. This will get you close when you put the dist. back in. Do NOT turn the engine while the dist. is out though.
Bryce
Brian630
10-21-2006 20:38:58
 Re: Screw for points in reply to shinnery, 10-21-2006 19:44:19
how do you know which way its pointing.
Not me
10-21-2006 13:46:15
 Beats Saving Credit Card Miles... in reply to Brian630, 10-21-2006 13:34:49
Couldn't resist.....
